Projects 31 ford build
Discussion in 'Traditional Hot Rods' started by Omarsvette, Dec 1, 2018.
  1. Omarsvette
    Omarsvette
    from Arizona
    I scored these cool headlights. Anyone know what they are off of so I can get a new trim bezel and headlight A7DECF2C-FBBB-4058-A8F0-06C8EE1C10B3.jpeg 8FD0089C-22F4-4E02-ACF2-EA3960821BF4.jpeg 9BFC286B-9644-4DB3-8567-245406C44D4E.jpeg
    osage orange, Stogy, patmanta and 2 others like this.
  2. brady1929
    brady1929
    Stogy and loudbang like this.
  3. Omarsvette
    Omarsvette
    from Arizona
    Thank, great website
  4. Omarsvette
    Omarsvette
    from Arizona
    Fittin the doors is such a task. I finally got my the drivers side , I’ll post pic later but it was tuff. The passenger is more of a pain cuz there’s a dent in the body B5DD12EA-340B-496A-99B1-4669F01B185A.jpeg A142BB45-5339-4C6F-938B-AAEAFC664FCA.jpeg
    Stogy, loudbang and brEad like this.
  5. Omarsvette
    Omarsvette
    from Arizona
    I had to cut down the floor to make the body sit evenly on the frame. 299DC8AE-AA16-42D5-9DDD-6C1B2ABBD0CE.jpeg 95B1CC80-3B6C-40F0-B826-7C3F84E78862.jpeg
  6. Omarsvette
    Omarsvette
    from Arizona
    image.jpg You can hardly see the dent to the left. Above the middle door hinge, The door bumps into it and doesn’t close without force. I cant show on photo but running your finger don’t the door jamb you can feel the bump. Should I grind or hammer? Or let the body man handle it?
  7. loudbang
    The part that bulges forward blocking the door will disappear when the body man removes the dent. Don't make his job harder by messing with it now. :)
    brady1929, Stogy and Omarsvette like this.
  8. Omarsvette
    Omarsvette
    from Arizona
    That’s my idea also. I’m glad I heard it from someone else. Plus I don’t want to make his job harder by grinding it down and making it worse.
  9. Omarsvette
    Omarsvette
    from Arizona
    Another cool score was a truck support off a 66 67 corvette. I love the mechanics because it holds on its own and self releases when you lower the lid. 577F30C5-0ADF-4480-9E48-EC95316F568B.jpeg E6EF0550-48AC-4891-9774-0945154DD97B.jpeg 9032F41E-13ED-4960-9E73-87642F182BD5.jpeg 5AC9567F-47D5-4708-814A-F4D8DC0066AF.jpeg 27B0C898-3917-4167-92FB-DB14529C34E6.jpeg
  10. Omarsvette
    Omarsvette
    from Arizona
    And I’m still going with the tank and battery in trunk...........any protest or you guys lookin for my demise hahaha image.jpg
  11. magnus13
    magnus13
    That's what I did on my roadster. Although I used a U3 tank and probably over fireproofed the trunk bay should something bad happen.
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  12. Stogy
    Stogy
    @Omarsvette I have a pic of a period vintage showing an option for your in trunk filling situation...you know the saying pics or it didn't happen...and heck it doesn't even look to bad...probably a hole, a vintage rubber gasket and a vintage cap some crafty pipework and Bob's your Uncle...
    The position in the pic looks forward of your tank position which is aft but you could elbow it over to a chosen location. I saved that pic as you don't see this fill position often...Fred had pretty unique wishbones as well...
    https://kustomrama.com/wiki/Fred_Larsen's_Second_1929_Ford
    Credit to Photographer, Owner
  13. Omarsvette
    Omarsvette
    from Arizona
    Ok stogy you got my brain workin. I love what you showed my. I think it’s very original. How about a lemans cap? I’m thinking a higher position, next to my lower trunk support bracket, closer to the roof edge, where it’s flat?
  14. Omarsvette
    Omarsvette
    from Arizona
  15. Stogy
    Stogy
    Its actually quite common in that tulip panel or adjacent quarter area...and it looks great to...but I wasn't sure that you were open to that...that's an option too...on my 29 sport coupe it's on the top quarter...the inner bracing is there just to make location more challenging.
  16. Omarsvette
    Omarsvette
    from Arizona
    ACEEDCE7-D831-4B17-9791-C85F0E8172ED.png That gas cap up high next to the top of the trunk line. It’s flat there and plenty of space. And like you said I’d have to fab some elbow pipe. pvc?
    loudbang and Stogy like this.
  17. Stogy
    Stogy
    :rolleyes:...:D...that is actually the exact one that's on mine...is your tank going in further or in place where it is?
    loudbang and Omarsvette like this.
  18. Omarsvette
    Omarsvette
    from Arizona
    Yeah man it’s a great idea. Thanks a lot. I’m workin on the tail lights now then I’m going to set up the tank. Then I’ll get that gas cap. I think it will look very cool/aggressive.
  19. Stogy
    Stogy
    In my trunk it looks to have a vinyl 2" or more dia. hose clamped from the cap to the tank fitting.
  20. Omarsvette
    Omarsvette
    from Arizona
    Haha very funny. I read your comment early at work and I started googling it. I have used a similar style on corvettes but they are wider. So I was happy to see a smaller one. The idea of making a hole on the side and using a corvette lid with the cross flags crossed my mind, but I like these lemans style caps.
  21. Omarsvette
    Omarsvette
    from Arizona
    I’m going to keep the tank in that position. I cant move it up more. I can go higher. I thought about cutting the filler tube and moving it around but I’m sure I can get a elbow.
  22. Omarsvette
    Omarsvette
    from Arizona
    I figured a radiator hose would work, wasn’t sure since we’re talking about gasoline.
  23. Stogy
    Stogy
    Not sure what hose will do...perhaps fuel grade rubber hose is available...But yeah molded hose might make life easier but is it fuel approved...some stuff you just want to know your safe. I will say I can't fill fast due to angle and bends...
    Actually alot of vintage cars probably use molded gas tank hose that look like rad hoses...
  24. Stogy
    Stogy
    Higher makes for a tighter fuel pipe install...it looks tight there as it is.
  25. Stogy
    Stogy
    I just thought it would be neat to see a side fill and it might even fill better...
  26. Stogy
    Stogy
    Here is that cap installed on mine...again be careful where you position it as there is inner bracing in that location.
    Mine is radically cut but I live with it.​
  27. Stogy
    Stogy
  28. Omarsvette
    Omarsvette
    from Arizona
    Very cool stogy!!!!i like what you did. That’s also were i was thinking of placing mine. I will take inconsideration what you said about the height of the tank. After looking at my tank and how the filler neck tilts to the left, it might be better to make a side filler. We will see.
  29. Omarsvette
    Omarsvette
    from Arizona
    There’s something really daunting about drilling holes... but I think it works out. Hole punch, template etc. 58EB16C5-960C-4F4E-8385-3C3168FED680.jpeg FD127941-25D1-4C9A-9A00-0234CFF88883.jpeg 4EB57774-5596-45B3-B94F-33ED8C98F64A.jpeg D91228B2-36F9-4404-A6DE-7CA9BFD2C991.jpeg
  30. Omarsvette
    Omarsvette
    from Arizona
    One more thing before I get into the gas tank, license plate. This is my plan. Look right? It won’t sit against the body, floating EE2EA767-C19C-45CB-B720-3DE3A4464956.jpeg 9769FFF1-9808-4B08-9D7E-B1C69AD1A23B.jpeg
    slv63, Stogy, loudbang and 2 others like this.
