Projects 31 ford build
Discussion in 'Traditional Hot Rods' started by Omarsvette, Dec 1, 2018.
  1. gimpyshotrods
    gimpyshotrods
    POR-15 is cured by moisture.
    LSJUNIPER likes this.
  2. Omarsvette
    Omarsvette
    from Arizona
    C4CA23F7-3883-468E-BEB5-60198C5DF651.jpeg Finally got the body bolted on. Sent my valve covers for chroming gonna work on my steering
    51box, Stogy, shortypu and 4 others like this.
  3. What are you planning for the steering?
    Charlie Stephens
  4. Omarsvette
    Omarsvette
    from Arizona
    Cross steer. I have a Vega box, going to so cal for a drag link with tie rods. I would like to use a bel air steering wheel but there huge. 18” seems bulky getting in an out of the car.
    Stogy likes this.
  5. ................Space your comment out from the quote with a few periods like this.:)
    Stogy and Dino 64 like this.
  6. Moon50F3
    Moon50F3
    from Mesa, AZ
    Thanks!
    Pat
    Dino 64 and lothiandon1940 like this.
  7. FlyingRN
    FlyingRN
    Harbor freight has an inexpensive mig cart for $39 Screenshot_20190122-070628_Chrome.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
    Stogy and LSJUNIPER like this.
  8. AHotRod
    AHotRod
    Hot Rod Coupes Rule!
    Love your Coupe, job well done.
    Omarsvette likes this.
  9. Omarsvette
    Omarsvette
    from Arizona
    im looking for a steering column. 32" is too long, the column would hit the heads or be too close when i sit. also because of the dash hangs low, the column is pushed down which brings the u-joint higher to the head.
    i think maybe a tilt column would be comfortable. my question is why isnt there key in column options, at least not many in the 28-30" length?
  10. Sometimes it is best to mock up the steering and motor placement at the same time, that way if you have to move the motor an inch you can do it. You should be able to cut the column down some, have you looked at that? Try to rethink the key in column thing, far cooler to have the key on the dash.
  11. AHotRod
    AHotRod
  12. Omarsvette
    Omarsvette
    from Arizona
    i would really hate to drill into my dash, i like how clean it came out. i have the motor in for mock up. but i cant move it forward anymore. ive looked into cutting a column vrs a ready to install. weighing the cost. and maybe key in dash.
    Stogy likes this.
  13. Omarsvette
    Omarsvette
    from Arizona
  14. haileyp1014
    haileyp1014
    from so cal
    Not sure about the vertical coil overs
    Dino 64, King ford and gimpyshotrods like this.
  15. Omarsvette
    Omarsvette
    from Arizona
    That makes two, but gimpy is
  16. sloppy jalopies
    sloppy jalopies
    Hot rod coupe !
    For the steering wheel I used a burr-bit plugged in my wizzer…
    cut away the back [lower] edge of the '37 banjo wheel's aluminum hub...
    cut / ground it till it matched the diameter of the speedway quick release hub...
    painted, it flowed with the Q/R hub...
    drill the [3] needed holes under the horn button to screw the wheel to the threaded Q/R hub... bingo
    this may work with the OEM steering wheels of your liking..
    pic later if needed, [raining hard].
  17. POR-15 is UV sensitive, don't use it on anything that will see sunlight (like wheels) or it won't stay looking good for long. They also make POR15 TopCoat which is UV safe.
  18. Omarsvette
    Omarsvette
    from Arizona
    Your right, I forgot about that, there’s a clear top coat to use to prolong the paint. Different than the top coat I put on the frame.
    Big A likes this.
  19. haileyp1014
    haileyp1014
    from so cal
    Sweet baby Jesus coupe looks killer on on her chassis now
  20. Omarsvette
    Omarsvette
    from Arizona
    thanks, im considering your tires on the avatar
  21. King ford
    King ford
    from 08302
    Greetings Omarsvette!...not to beat a dead horse but I am curious what you are looking to change in your ride quality with the vertical coilovers?...also if you do see an ( in my humble opinion unexpected) improved ride quality but a lack of body roll control you could add a rear " antirool" bar ( some call it a sway bar) ...also I LOVE your body modifications, dash is ROCKIN!
    Dino 64 likes this.
  22. Omarsvette
    Omarsvette
    from Arizona
    oh that horse has died and ressurected and has become a zombie on this post.
    if you go to instagram under onalleight or my name omar aguila, you can see some pics of my last build. 31 ford truck on A chassis with coilovers and ladder bars. now that ride was very stiff and bumpy. the coilovers were set at 25deg angle and maybe 195lbs coilover. on turns it was great but i could feel the road alot. the tires were cooper cobra 265-60-15ish? brand new, i would even lower the air pressure.
    now i understand why angle coilovers are ideal. actually shocks should be next to the wheel hub then attached to frame for maximum use of shock. but with design of chassis they get tilted in. since we dont have that option in our cars, the shocks end up inside the frame.
    my thought is maybe itll be softer vertical . currently the body rocks up and down and sideways normal like the springs are working.. not hitting the wheel or ladders binding. but ill no for sure when i hit the road.
    its going to be a trial thing. maybe i had too stiff spring in my truck or i set something up wrong or whatever. but i could always tilt them in my coupe if something goes wrong. has anyone here actually run vertical coilovers with a ladders on a model A? not what you heard or what your buddy did or read but real life experience?
    i agree with your post, im 50/50 it will improve, i do think angle with lighter coilover might better and if it is unexpectedly better but with bodyroll, then i could add a sway bar..........or just fix the damm coilovers:)
    King ford likes this.
  23. gimpyshotrods
    gimpyshotrods
    I'm-a just leave this here:
    Dino 64 and King ford like this.
  24. Omarsvette
    Omarsvette
    from Arizona
    Right that’s my thought. At vertical the spring is working at 100%. The more you tilt, the less effective it is. Which is why you go for a stiffer spring. Which I did in MY truck.
  25. Omarsvette
    Omarsvette
    from Arizona
    1)The fact that the coilovers are straight up and down will disallow any natural body roll control that a coilovers installed at an angle have-your post gimpy
    2)but a lack of body roll control - is king fords post
    one is saying the body is supposed to roll while the other is saying it’s not. Some others are saying the shocks won’t work on turns. I thought the body would be stiff but like I said the shocks react when you shake the body around. That’s why gimpy, I ask if you have ever ran vertical shock, experience as to what the car does.
  26. gimpyshotrods
    gimpyshotrods
    You are totally misunderstanding these comments.
    He and I have said exactly the same thing.
    We both have said that coil-overs mounted straight up and down to not have the built in body roll control that tilted ones do.
    As for what I have run, I don't run vertical coil overs on anything but a dedicated drag-race-only car, that is not expected to turn, or be operated on a public road. Most of those also have an adjustable anti sway bar, as well.
    As for what my experience is, I am a Senior Automotive Engineer at a little car company known as General Motors.
    I build powertrain, control, and suspension systems.
    Stogy and kidcampbell71 like this.
  27. Omarsvette
    Omarsvette
    from Arizona
    Vertically mounted shocks will control suspension movement, but on a street rod, most shock manufacturers recommend mounting shocks at a slight angle (viewed from the front or rear). This increases handling by limiting side to side movement, which will decrease body roll during cornering. On most street rod applications a mounted angle of 15-25 degrees is preferable for great handling
    This is the other part of your article. And I get it, especially the closer together the shocks are mounted the more body roll. Now look at my set up, and there’s a Panhard bar which limits sideways chassis movement. Now think of this, 90%of driving is a straight line, whatever turns there are, are taken at a very low speed. I’m not squealing tires hear. I’m not pulling Gs and neither is anyone else on this forum with these cars. I wanna control suspension in a straight line where most of my driving is. Ever drive a tri five Chevy and experience there bodyroll? But very nice straight. Or a C3corvette which has very impressive suspension, and they still experience bodyroll without a sway bar (they have vertical shocks with transvers spring). I think My setup will have very little sideways movement. Especially with the weight difference between the other examples. Im trying to think logically here. And how I plan to use this car. Do you honestly think my ride will suck or break with vertical coilovers given what I said and how I plan to drive, do you think I’m going to have excessively high body roll or the chassis is going to fishtail making turns at say 5mph?
  28. Omarsvette
    Omarsvette
    from Arizona
    Your right both of you said the same thing, I missed read because I was debating with you instead of enjoying building my Hemi coupe. ;)
    Stogy likes this.
  29. gimpyshotrods
    gimpyshotrods
    A Tri-5 Chevy has IFS, which makes for a different CG/roll/sway dynamic, so that does not apply. Your Corvette example is specious. That is not the same suspension setup, in any way.
    You are under no obligation to either listen to me, or build a car that could handle as well as it should. That is all on you. If it handles poorly, you, and the new owner get to live with that.
    Several people who know of what they speak came here and gave you sound advice. You discarded it. I could bring a few more people to the thread that know even more that I do, but I doubt it would help.
    I have built a couple hundred cars for happy customers. It work, I had a hand in about 300,000 more. No complaints there either.
    FlatJan and Stogy like this.
  30. Omarsvette
    Omarsvette
    from Arizona
    Ok gimpy, give me a minute to redeem myself...........
    Stogy likes this.
