305h-10 comp. cam
Discussion in 'The Hokey Ass Message Board' started by 18436572, Nov 8, 2009.
  1. 18436572
    18436572
    Has anyone used this cam? and if so did you like it.... I'm looking to replace my old bumpstick (30-30 Duntov) with something else.
    I have a 355 with a set of sportsman 2 heads, headers,intake,msd, 3000 stall ... so on and so on. I just wondered if the 305H would be too much for the street :confused:
  2. Rich Rogers
    Rich Rogers
    Is there such a thing as too much? Granted that's alot of cam but it sure would sound great but they've been run on the street before. Does your intake match up to the rpms of the cam or come close? If it does , imo I'd say go for it
  3. AnimalAin
    AnimalAin
    Every hot rodder should have a motor with too much cam. Well, you ought to do it at least once.
    The best advice is to talk to the people on the cam tech line. Maybe call more than one vendor, and see what the general consensus is for your application. The cam companies have a lot of experience with their products, and a vested interest in you being happy with your selection.
  4. I have used it several times. it is very similar to the old Sig Erson (Pre Erson) 525H cam. It needs everything right but is brutal when working good. Will rev as much as you want i think. Can go to 7000 although best power is a couple of hundred RPM lower. Needs a short quick distribtor curve. If your a good tuner it will be a killler cam. It should use a bit more converter but it will be drivable with what you have. I pay the extra now to have comp nitride my cams. A oz of prevention and all that. With the lack of good oils I think it is money well spent.
    Don
  5. skajaquada
    skajaquada
    from SLC Utard
    tsk tsk...there you guys go with off the shelf cams again. I know for a fact you can get a better cam custom ground to your application and desires for cheaper than that one.
  6. brandon
    brandon
    a 280 magnum or a lunati 292 street master (or what ever those are called) would do probably nicely....granted cam technology has came a long way since those were made. brandon:D
  7. brandon
    brandon
  8. sdluck
    sdluck
    I vote to have a cam ground based on componets in the engine,I use Dema Elgin.
  9. Glen
    Glen
    amen....I use bullet cams www.bulletcams.com
    Heads respond differently....for example my Brodix heads like a split in duration so a 305H would be a terrible idea, no matter how perfect everything else is.
  10. ridin dirty
    ridin dirty
    Bigger is better and too much is just right!!!!!!!!! LOL I had a 305H in my BBC 396 oval port heads and it felt like a pig compared to to the Crane Cams L88 blueprint cam. Talk to Bullet or UDHAROLD Aka designer of the Voodoo cam line foe Lunati. He is to be found on chevelles.com
  11. 18436572
    18436572
    Thanks for the info guys, I'll study the other options given and then make a choice in a week or so.
