305/350 bogs when put into gear.
Discussion in 'The Hokey Ass Message Board' started by mack57, Jul 13, 2013.
  1. mack57
    mack57
    Hi all!
    I have a'48 chevy coupe with a 305/350 combo. Recently replaced a homemade tranny crossmember and raised the tranny 2-3". Now, the idle is smooth as usual but when put into gear the motor bogs and stalls if allowed.... The only thing that I think was effected was the shifter linkage.
    Any thoughts??
    Mack
  2. Is the vacuum modulator hooked up?
  3. hoop98
    hoop98
    from Texas
    Make sure the distributor cap isn't making contact since you raised the trans.
    Do a stall test, should be able to go over 1500 against the brake. if not the converter overrunning clutch is bad.
  4. blyndgesser
    blyndgesser
    from Georgia
    Maybe got the TV cable out of adjustment?
  5. Deuces
    Deuces
    from Michigan
    Carb floats may need to be reset...
    I could be wrong..:eek:
  6. mack57
    mack57
    I installed the carb a month or so ago, ran super from 1st start. would that angle change cause a float problem? possibly an air/fuel mixture change would help?
    Thanks,
    Mack
  7. mack57
    mack57
    I'm sorry, what is the TV cable?
  8. mack57
    mack57
    Distributor is clear, and strong at 1500.... I'm stumped....
  9. mack57
    mack57
    Vac line from tranny is connected. was runnin great.... I'm stumped as to why the angle change has made a diff. I could understand if it was grinding/screeching as if something was bound or rubbing against something else but....
  10. There is no TV cable on a T350. Just a kickdown cable.
  11. mustang6147
    mustang6147
    from Kent, Ohio
    Compression check. Make sure all cylinders are makin power.
    Either a plugged idle circuit, or the engine is tired...
    A hell of a carb angle if the engine is tilted to far forward, you might need jet extensions in the front???? Is it a Holley? try raising the float level in the front bowl.... That would be a hell of a lift...
  12. hoop98
    hoop98
    from Texas
    What is the Carb pad angle? Your phone probably has an inclonometer app available
  13. landseaandair
    landseaandair
    from phoenix
    Could the distributor have contacted the firewall and changed timing a bit when the cross member swap took place?
  14. What's the outcome here ?
  15. mack57
    mack57
    Hey guys,
    Sorry, I got a bit sidetracked.... I pulled the plugs and found one was fouled very bad with an oil leak from the rear corner of the valve cover. changed the plugs and the cover gasket & she's back in business. The carb I think still needs to be tuned a bit due to the new angle but, NOT bogging when in gear now.
    THANK YOU GUYS!!
