Technical 303 Oldsmobile engine
Discussion in 'Traditional Hot Rods' started by henry76, May 11, 2019.
  1. henry76
    henry76
    Engine been sitting for about 4-5 years and I don’t want to dry start it. Can i prime it like a small block Chevy and get the oil primed? Have occasional been spraying wd40 in spark plug holes and hand cranking during the years. It’s a cool engine Preditor cam Chevy valves 3 twos etc
    OLSKOOL57 and Deuces like this.
  2. Doublepumper
    Doublepumper
    Yes. Prime it in a counter clockwise rotation. Best to rotate the engine a quarter turn (clockwise) and repeat a few times. I like to use some MMO in the fuel at startup on engines that haven't been run in awhile also.
  3. F&J
    F&J
    Unlike Chevy, there will be no oil showing at the rockers if the cam is not rotating. That's because the oil path to each bank goes right through a cam journal, but only when the cross drilled holes line up once every revolution of the cam.
    Sounds like a cool engine to me. :cool:
    mgtstumpy, OLSKOOL57, Deuces and 2 others like this.
  4. henry76
    henry76
    Thank You
  5. henry76
    henry76
    Thank You
  6. sololobo
    sololobo
    rocket 88 one of the early way cool hot rod mill, sounds like a nice build also
