Customs 302 with blown head gasket?
Discussion in 'The Hokey Ass Message Board' started by Los_Control, Jun 12, 2019.
  1. Los_Control
    Los_Control
    from TX
    Hope you can offer some advice, working on my neighbors shoebox.
    Is a nice car, all original except for a newer 302 in it.
    He bought it a year ago and never drives it ... I asked why, it is overheating he said.
    So I offered to fix the cooling system, T-stat was stuck, water pump bearings are gone, electric fan dead, I flushed the radiator, new hoses.
    Has a 195 T-stat and runs at 190 when warmed up, goose the throttle and cools right down to 180 now ... cooling system is now working.
    But while idle in the driveway with no radiator cap, and not over heated, it is blowing water out the top of the radiator.
    I am guessing a blown head gasket, will buy the test kit today to confirm it.
    My question is, moving forward from here.
    The motor runs smooth and solid, just touch the key and it is running.
    It runs smooth, it has plenty of power.
    Does anyone think it is a good idea to just slap a set of head gaskets on it?
    Or do I need to take the heads to a machine shop and checked?
    Since I have not yet confirmed the head gasket, any other possibles on a 302 ford blowing coolant out the radiator?
  2. squirrel
    post a video of what you see going on with the radiator.
    Does it lose coolant in normal driving?
    The test for exhaust in the radiator will tell you what you need to know, though.
    Los_Control, Deuces and ffr1222k like this.
  3. southcross2631
    southcross2631
    It can run smooth and still have a leaking head gasket. I agree with Squirrel exhaust in the cooling system makes them boil over.
    I recently did a 350 that sounded good and ran perfectly except it couldn't keep the coolant in the radiator. Replaced the block and reused all of the internal parts and the heads . No issues after that.
    Los_Control likes this.
  4. Los_Control
    Los_Control
    from TX
    Ok, is warming up now, takes about 20 min idle to warm up
    Guarantee it did before I replaced the cooling system, got it back together last night and not driven it on the road.
    Exactly what I plan to do next ... if positive to have exhaust gas, and it was my car, I would just put a set of gaskets on it and pray.
    When helping a friend, am not sure is a good idea.
    I still need to go buy the kit though.
  5. Beanscoot
    Beanscoot
    When and if you have the heads off, you will be able to make a better decision about having work done on them.
  6. sunbeam
    sunbeam
    Those kits work great would not buy a used car without one. Especially if the car has aluminum heads. Went car shopping with grandson 3 out of 5 cars he liked failed.
    Los_Control and squirrel like this.
  7. Los_Control
    Los_Control
    from TX
    Here is the video ... I am simply trying to fill the car with water and test for leaks etc..
    The longer you run it, the more often the water spurts out, and the higher it spurts.
    This is why I have not driven it. .... I cant first get the water level to settle, I do not think this is normal.
  8. Los_Control
    Los_Control
    from TX
    I think my neighbor paid $7500 for this car, bragged a little about the great deal.
    So far he has driven it 35 miles in 1.5 years :(
  9. Oldioron
    Oldioron
    Stock iron heads?
  10. Los_Control
    Los_Control
    from TX
    The engine is stock with no modifications.
  11. squirrel
    How full is the radiator, when it's cool, and not running? as in, how many inches below the bottom of the filler neck?
  12. Blacktop VooDoo
    Blacktop VooDoo
    You mentioned that it takes 20 minutes to warm up at idle. In my experience, a bad head gasket will cause it to heat up much faster then that.
    JeffB2 likes this.
  13. Los_Control
    Los_Control
    from TX
    Right now it is sitting 1.5" below the neck.
    I only let it run long enough to show the symptom.
    But yesterday, I let it run for 1 hour. It just continued to spit water out and had to use the hose to keep adding water ...
    Maybe I just need to slap a cap on it and drive it, then see where it is at.
    loudbang and JeffB2 like this.
  14. squirrel
    yeah, that's what I would do!
    Los_Control and JeffB2 like this.
  15. Blacktop VooDoo
    Blacktop VooDoo
    Yep, I'd cap it and drive it. Just don't venture too far---just in case.
  16. farmalldan
    farmalldan
    from Duncan, OK
    Reminds me of my '54 Ford from high school. 332 fe, stock radiator. It would set idling with radiator cap off and periodically geyser like that. Did fine with cap on unless you flogged it for a bit and then shut it off. Often, it would blow a radiator hose off within a few minutes of shut down. When I finally got tired of it, I discovered the water pump had a phenolic impeller which had broken in half. New water pump solved the problem. You dont have a reverse rotation water pump, do you?
    Los_Control, JeffB2 and s55mercury66 like this.
  17. Smokeybear
    Smokeybear
    did you change the water pump?
  18. evintho
    evintho
    What is this kit you speak of??
  19. 62rebel
    62rebel
    Never had a Windsor that had a heating problem; guess I been lucky. I had a 383 that would puke it's guts out but I found the head gaskets clogged, not blown. Another problem that I ran into was a bad bottom hose that would suck flat once the rubber got hot. I was sure that car was a goner; a new radiator hose with a strong spring in it cured it.
    6sally6, Los_Control and Deuces like this.
  20. Ericnova72
    Ericnova72
    Video looks normal for a top tank vertical flow radiator and no cap on it.
    Water level needs to be at least 3" down from cap if it doesn't have a hose leading to a return tank type set-up on it... It can only be filled to the top with a recovery tank. The old dump the overflow hose onto the ground systems need lots of expansion room or that will push a lot out.
    I'm with the cap it and test drive it group, add a recovery tank if it does okay in the drive test.
  21. Los_Control
    Los_Control
    from TX
    Pretty sure this might make me a criminal. The insurance card is not in my name, the registration expired last month.
    Maybe I can get my neighbor to drive his own dang car.
    Let me show you this video, this is while it is warming up before the T-stat opens.
    I understand, I just need to do the test, this is what I am seeing and why I need to do the test.
    To me, this is just not normal ... I have been wrong before.
  22. Los_Control
    Los_Control
    from TX
    I apologize for being stupid, this just does not look right to me.
    Been a long time since worked on a car like this.
  23. squirrel
    do you see bubbles of "air" coming up in the radiator?
    Does it smell like exhaust in there?
  24. Oldioron
    Oldioron
    I can't remember ever having a little Ford with a bad head gasket but I'd let the water get down to a level that you could see it in the rad. If compression is getting into the cooling there will be large amounts of air in the coolant.
  25. goldmountain
    goldmountain
    Los_Control and bobss396 like this.
  26. GordonC
    GordonC
    Was the motor sitting on hi idle while running with the radiator open? It sounded like it to me in the video. If it was I would top off the rad and cap it and then tool around the hood a little bit to see what it does. I've had cars before push coolant out when on hi idle or revved up that were fine when capped and being driven.
  27. 302GMC
    302GMC
    from Idaho
    Borrow a pressure tester & take the plugs out. Pump it up & crank it over in an hour or so. Don't stand in front of any plug holes ….
    Los_Control, loudbang and Terrible80 like this.
  28. porknbeaner
    porknbeaner
    That's not a blown head gasket its just blubbing from the water pump working. A blown head gasket looks like a fire boat.
  29. sunbeam
    sunbeam
    Los_Control and loudbang like this.
  30. LM14
    LM14
    from Iowa
    I think you are seeing a radiator that is too full. The first video just looked like the thermostat opening and closing to me. Nothing to worry about. I've never had a blown head gasket on any Windsor style Ford, even race engines. My guess is you are worrying about nothing and seeing how things looked before closed systems came into play on everything.
    SPark
    Los_Control, loudbang and bobss396 like this.
