Technical 302 Windsor heads
Discussion in 'The Hokey Ass Message Board' started by vtmopar, Jul 29, 2016.
  1. vtmopar
    vtmopar
    from Vermont
    I'm putting parts together for my 42' coupe engine.
    the heads I have are off a 72' truck
    I'm not building anything special my question is instead putting money into those should I consider a set of gt40 heads instead?
    Any fitment issues I should consider?
    What manifolds should I also be looking for?
    Thanks
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  2. 65COMET
    65COMET
    The GT40 heads would be an upgrade but they take special exhaust manifolding! If you can,get the exhaust with the heads!! ROY.
  3. If those 72 heads take much work, you're better off saving up and getting aftermarket aluminum heads. Or, if you're like me, you like to spend hours grinding down thermactor humps and opening up the exhaust runners because you don't really have a life, go for it.
    chessterd5 likes this.
  4. vtmopar
    vtmopar
    from Vermont
    Thanks I'll make sure to grab the manifolds when I grab the heads
  5. Mike51Merc
    Mike51Merc
    Only the GT40P heads have the spark plug/exhaust manifold issue. True GT40 heads do not.
    JeffB2 likes this.
  6. You'll need new pushrods with the GT40 heads too. The ones off the roller cam donor motor won't work, they'll be too short with a flat tappet cam. The 'P' heads will give a bit more compression, but also have valve rotators on the exhaust and valve springs that won't cut the mustard with a hi-po cam, so these aren't a 'simple' bolt-on. Both heads are worth about 25-30 HP give-or-take at the top of the tach, less down lower.
  7. Mike51Merc
    Mike51Merc
    The GT40 heads also have the rotators, but they can be eliminated with a set of offset valve retainers (specifically for eliminating rotators) from Ford Racing (plus I recommend the matching valve springs from Ford) that will result in equal spring heights.
  8. pie pie
    pie pie
    from missouri
    I'm running the p heads on my engine. you just need plug wires with 90 degree boots and headers. manifolds wont work. They run fine. I have changed the valve springs away from the rotators. My car made 299 ft lbs to the wheels with these heads on a stock short block.
  9. Kerrynzl
    Kerrynzl
    If you're not building anything special, just plonk a set of late model E7' heads on it.
    They have herdened seats for modern gas and are "cheap as chips"
  10. CyaNide
    CyaNide
    from Texas
    Don't waste the money on e7 heads. Might as well keep the old heads. Gt40 and P heads are great. Or find early 70's 351w heads. I think pre '73.
    CN
  11. Kerrynzl
    Kerrynzl
    The early heads aren't suited for Unleaded Gas, and the cost of hardened seats is more than a pair of E7's
    He could sell the early heads.
    Ford explorer heads are a better choice [GT40P's] at a cost
    We can all be internet heroes when it comes to spending other peoples money
    The OP did say "He wasn't building anything special"
  12. 65COMET
    65COMET
    Early 69-70,351W heads have huge combustion chambers and will need domed pistons to get you back to a decent compression!Later 351W heads are the same as 302-5 Liter heads! ROY.
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. vtmopar
    vtmopar
    from Vermont
    Thanks for the replies
    Jeff thanks for the link good info there.
