Anyone know if there is clearance for this combo? 302 Ford with Weiand 1988 tunnel ram, 390 Holleys mounted inline, and a Vertex mag? thanks
Is the mag any larger than a stock distributor? If it's only taller than it should work depending on how much taller. A little time on the mill should solve any clearance issues otherwise.
The only pic I can find that is even close is a Vertex with a 2x4 Edelbrock with AFBs, which clears by about .250. The Holleys are longer front to back, but hopefully the tunnel ram will be tall enough to get over the top of the mag...
