From 1988 GT. Roller engine. 80,000 miles. Still can see hatch marks in cylinders. Heads and cam are off/out. I wanted to check it out inside. It comes with: Wieand dual plane intake (#____) 4 barrel Holley vacuum secondary carb. (#_____) Valve covers-powered by ford (bronco) Bronco oil pan (allows better fit in a '36-'40 frame) Distributor, coil Water pump, power steering pump, other misc. In another ad/post I have a bell housing for SBF to early ford 3 speed transmission. Clean it up and paint it. Cheap! Local pick-up.
