Just bought a 302 and aod out of a 80 lincoln continental...I'm gonna put an intake and carb on it, how to I make the kickdown work? It was originally a throttle body injected car and I hav the kickdown stuff from that, can I make that work? Thanks in advance Cody
If the stock stuff doesn't work, I think Lokar has a TV Cable Kit for the AOD, it's in the $80 range if I remember right. I'll be using a '90 Lincoln 5.0 EFI/AOD myself...carbed of course, but thinking of swapping the AOD for a C4...dunno yet.
LOCAR makes the correct kickdown linkage, a little touchy to adjust but works very good.....................OLDBEET
Just in case you do not know this: that linkage from the carb to the AOD trany is NOT a kick down. It is a TV linkage, it must hooked up and adjusted correctly. Or you will smoke the AOD real quickly
