Projects 30 roadster help
Discussion in 'Traditional Customs' started by Bcchooligan, Mar 28, 2016.
  1. Bcchooligan
    Bcchooligan
    from Mass
    I'm in the process of building a 30 model a roadster.......all I have is the cowl and rear quarters,my question is does anyone know the width of the doors and the inside width of the quarters behind the doors so I can weld in some 1x1 ...thanx
  2. Why don't you get the lower deck panel, and the upper deck panel to give you a good start. I would give you the dimension for the quarter panel width, but my roadster is channeled. I can give you the dimension between the door jambs if it will help. nick.
  3. The37Kid
    The37Kid
    You really need to buy a set of subrails, you can't build a house without a foundation. Bob
    mike bowling, kidcampbell71 and slv63 like this.
  4. And doors, wouldn't count on them fitting if you don't build around them.
  5. fatty mcguire
    fatty mcguire
    prolly get a lot more help in the hot rod section
  6. woodhawg
    woodhawg
    1. S.F.C.C.
    My passenger door does not fit well and the body is original Ford stuff, never apart. I agree start at the bottom and build up.
  7. Bcchooligan
    Bcchooligan
    from Mass
    It would be pointless to spend the almost 500 on subrails when I'm just going to cut them up to channel it over the frame
    Sent from my SM-G925T using H.A.M.B. mobile app
  8. Bcchooligan
    Bcchooligan
    from Mass
    What do you have for measurements?mine will be channeled as well
  9. The37Kid
    The37Kid
    Most people start at the beginning, have fun. Bob
    mike bowling likes this.
  10. mike bowling
    mike bowling
    "In the Beginning"------------
    Joel W and The37Kid like this.
  11. I measured mine today, distance from cowl to door jam centered is 22 3/4. Width of top panel between quarters is 37. Width of lower panel between quarters is 35 1/2. Width between quarters centered at door guide is 46 3/4. Not sure how most people channel a roadster but I have read where they do use the subrails to retain the orginial floor and move the body down the channel they want or move the frame above them instead of below them. Not for everyone though. Good luck. .
  12. sloppy jalopies
    sloppy jalopies
    This weekend i made a "cabster" subfloor with [2] 1" tubes [conduit] 1" apart, the'top centers' of the tubes are 2" apart, i had some 2" steel strips, used them as caps... makes a pretty nice subfloor for under $50.00 ... rear kick ups after i add the quarters...
