I see some have had problems with these not fitting when using radius rods or split bones...cant seem to find any specs on these other than overall dimension and nobody is answering calls.... Can anybody tell me the dimension from Center of front mount point to front of tank? 30-31 tanks
I don't know the dimension, but when I looked into them a number of years ago, you needed to run a four bar front to clear the tanks.
yeah I'm using hair pins ...I'm gonna see what I can do to foi a mustang tank under the back of the bed , I will be happier with it anyway if it works out the way I want... good deal on saddle tanks, if somebody can use them: http://www.chassisengineeringinc.co...-gas-tank-saddle-pair-each-38x7x-9-swap-meet/
I have a custom made tank that fits inside the frame on the drivers side and the driveshaft. Holds about 12 gallons.
