'30 - '31 Model A Roadster Steel Body
Discussion in 'Cars For Sale' started by rottenleonard, Oct 2, 2017.
  1. rottenleonard
    City: Lewiston
    State: Idaho
    Price: 16,500
    Start your Model A roadster build off right with Rotten Leonard’s Jalopy Shop. We are now offering ‘30 - '31 Model A Roadster Reproduction Cars. The body panels are stamped at Brookville Roadster and the panels are assembled on a Rotten Leonard’s Rectangular Style Subfloor right here in house. If you are interested in this car, it runs at $16.500 and is all ready to go. (H.A.M.B. Alliance members get a $500 discount!)
    The specifications of our reproduction roadster build are as follows:
    The Body
    Our reproduction ’30-’31 Roadster comes with steel body panels stamped by Brookville Roadster, a tip out dash for easy access to the pedal assembly, wiring and gauges, a widened floor for extra foot room, tubular sub-floor, 14-gauge bonded and screwed sheeting construction, and a compact rear differential clearance pocket; the trunk assembly and doors are hinged and latched, with ’28-’29 style latches being used for the doors (no outside door handle). The windshield and frame is our Rotten Leonard Hallock Style windshield. Our firewall is a Rotten Leonard style, V8-stamped recessed firewall. To prevent any cracking or shrink-back in the body, the body seams have been tig welded with silicone bronze. The front end of the car will be fitted with Model A wishbones, a So-Cal 4” forged drop axle, F-1 front drum brakes with new shoes and wheel cylinders, chrome dropped steering arms, and chrome front shocks with Rotten Leonard style upper shock mounts.​
    Frame Specifications
    The frame in our reproduction roadster includes JW Rod Garage frame Rails, Rotten Leonard style full boxing plates, a Rotten Leonard style heavy-duty K-Member, JW Rod Garage front cross-members, and removable wishbone mounts. We also include a Rotten Leonard, Hurst Style engine mount, and a combination transmission/ ladder bar mount fitted for the NV 3500 5-speed transmission. This transmission mount allows for easy modification for different transmissions. We also include front and rear spreader bars, rear tube shocks, a rear Rotten Leonard style drilled rectangular-tube cross-member, a Core Ford 9” rear axle with center section axles, and a Rotten Leonard style spring hanger with ’40 Ford transverse spring. The Chassis will be constructed on your chassis table using our proprietary jigs.​
    Additional Options
    While these options are not included with our base package, we can also include a steering box mount, a pedal assembly, wheels and tires, or any other modifications you would like performed at a time and materials rate(shop time is $75/hr, parts/materials are marked up 20%, you can provide parts if you prefer)​
    New Brookville Body Panels
    Widened Floor
    Includes tubular sub-frame
    14G Floor sheeting
    Bonded and screwed sheeting construction
    Compact rear diff clearance pocket​
    Tip out dash for easy access
    Hinged and latched trunk assembly
    Fitted and welded RL Hallock Style windshield
    Doors– hinged and latched w/ 28’ 29’ latches
    Body seams tig welded with silicone bronze to prevent shrink-back and cracking
    RL stamped V8 recessed firewall​
    Split Model A wishbones
    So-cal 4” forged drop axle
    New shoes and wheel cylinders​
    Chrome dropped steering arms
    Chrome front shocks with upper RL mounts​
    JW Rod Garage frame rails
    RL full boxing plates
    RL heavy-duty K-member
    Removable wishbone mounts
    RL combination rear
    Ladder bar / trans mount
    (allows easy modification for different transmissions)
    Currently setup for NV3500 5-speed transmission​
    Front + rear spreader bars
    Rear tube shocks
    RL rear spring hanger w/ 40 Ford transverse spring
    Core Ford 9” rear with center section and axles
    Setup for SBC and NV3500 5-speed trans​
    RL drilled rectangular tube rear cross-member​
    Also available at extra cost:
    Steering box
    Brake pedal assembly
    Wheels and tires
    Basically any other modifications you would like performed at a time and materials rate(shop time is $75/hr, parts/materials are marked up 20%, you can provide parts if you prefer)​
    Check out our website for more pictures:
    20170803_080147 - edited.jpg 20170803_080205  - edited.jpg 20170803_080536 - edited.jpg 20170803_080905 - edited.jpg 20170803_080920 - edited a.jpg 20170803_080932 - edited.jpg 20170803_081011 - edited.jpg 20170803_095047 - edited.jpg 20170803_095133  - edited.jpg 20170803_095203  - edited.jpg 20170803_095227 - edited.jpg 20170803_095237  - edited.jpg 20170803_095819  - edited.jpg
    Darryl Deir, ls1yj, RICH B and 5 others like this.
  2. rottenleonard
