30 - 31, Model A door dimensions
Discussion in 'The Hokey Ass Message Board' started by monc440, Feb 27, 2012.
  1. monc440
    monc440
    Help, Can someone give me the measurements on Coupe or Todor Sadan doors.
    Would like the following filled in;
    Front of door top to bottom = xx.xx"
    Rear of door top to bottom = xx.xx"
    Top of door front to rear = xx.xx"
    Bottom of door front to rear = xx.xx"
    Body line front to rear = xx.xx"
    Pics would be real cool :eek:
    Thanks
  2. monc440
    monc440
  3. speed-kings
    speed-kings
    Coupe and sedan doors are different. Sedan doors are around 2 inces longer.
  4. 31Apickup
    31Apickup
    30-31 Tudors and pick-ups use the same door , coupe are narrower. A quick way to tell without measuring is a coupe door has a circular stamping on the inside of the door at the window crank, sedan doors do not. The attached picture is of a coupe where you can see the circular area.
  5. monc440
    monc440
    That info helps but...
    OK here goes. I have been looking for a driver side door for my 31 Plymouth for a year now and my dad had this body for the last ten years and didn't come accross a door at swap meets here in Michigan. So this weekend while I was looking for some parts in the back barn a cam across a Ford 30-31 4 door sadan driver side front door and I thought what the hell I'll see how close it is to the plymouth door. I take it up to the front shop and the three hinges and height are damb close but it was not long enough. The body lines are not the same but I can fix that alot easier than making an entire door. I was asking for the measurements so I could compare them to the my passenger side Plymouth door.
    Thanks
  6. F-6Garagerat
    F-6Garagerat
    I know that a sedan/truck door is 29"-29 1/2" from cowl to rear door opening/b pillar
  7. monc440
    monc440
  8. PGraham55
    PGraham55
    What is the measurement of the Fordor door front to back? I have a similar project and am trying to ID the doors that came with it.
  9. wagoon78
    wagoon78
    30 sedan
    Top width 29 3/16"
    Bottom width 29"
    Height near hinges 43 7/8" on the curve
    Height near handle same
    Hope this helps
