30-31 A cowl question
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Dec 27, 2008.
  1. Toqwik
    Toqwik
    Is there any difference in coupe / sedan cowls on a model A? In other words, will a sedan cowl work with a coupe?
  2. temper_mental
    temper_mental
    from Texas
    With my limited amount of knowledge I would say yes .My 2 cents
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    The cowl from a 30-31 Tudor Sedan, any Coupe and any Pickup should be the same, BUT I wouldn't be sure about the Fordor Sedans since they were wood-structured except for the Slant Windshield ones in late 31.
  4. 28hiboy
    28hiboy
    from milton fl
    2 dr cowl will work but not 4dr or vicky or slantwindow. PU will work too.
  5. Toqwik
    Toqwik
    What is different about a 4 door cowl? Reason I asked, my coupe is in pieces and there are some 4dr sedan doors with it that look like they could be from the same car as the cowl.
  6. superbell
    superbell
  7. Toqwik
    Toqwik
    The cowl I have does not have any wood structure to it. Do all 4 door cowls have a wood structure?
  8. Ford used 2 manufacturers for bodies in 30-31. Briggs & Murray. Four door non-slant window cowls should be the same as coupe PU & 2 door sedan if you have the same body manufacturer. I think all slant windows were Murray & were mostly steel. Briggs used wood frames & nailed the sheet metal to the wood frame. Four Door front doors are narrower (front to back) than coupe & 2 door sedans doors. Slant window cowls (all 1931 model year) were on Vicky's, Slant window Town sedans, 400A, Cabriolet 68 B&C and some speciality Limo's.
    I've got lots of Model A books & literature if you need more info.
    Movin/on
  9. MR. FORD
    MR. FORD
    from Austin, TX
    Four door and Vicky cowls are different. Coupe, 2 door sedan, and truck should all interchange. The doors are shorter on a coupe, truck and sedan are the same.
  10. kb cookout
    kb cookout
    30-31.. sedan, pick-up, sedan delivery are the same .
    30-31 coupe and panel delivery..( looks the same as the ones listed above), but the upper door hinge in is a different location
    later kb
  11. Zookeeper
    Zookeeper
    Yup. I have a '30 p/u, my brother and Mom have '31 sedans and Dad has a '31 coupe, and coupe cowls and doors differ from the rest.
  12. Toqwik
    Toqwik
    So is the only difference in a 4 door cowl and a coupe cowl is the location of the upper hinge? I have coupe doors, so that is not an issue. Just need to determine if I have a 4 door cowl or a coupe cowl...
  13. Toqwik
    Toqwik
    I measured the distance from the 2nd and top hinge on my coupe doors, and the distance in the 2nd and top hinge on my cowl and they match. Does that mean I have a coupe cowl?
