3 speed trans help
Discussion in 'The Hokey Ass Message Board' started by espi1, Mar 24, 2013.
  1. espi1
    espi1
    I have a 52 chevy hardtop with an upgraded 302 inline 6 and original 3speed with a mcleod clutch. Linkages all working properly and clutch adjusted many times. But when the car warms up the clutch won't disengage. Any experience with this?
  2. 226 flattie
    226 flattie
    from orange,ca
    Sounds like you have a bad clutch.
  3. espi1
    espi1
    actually tried 2 new clutches
  4. Okatoma cruiser
    Okatoma cruiser
    from Ms
    If you put it in gear with the motor off- hold the clutch down and start the motor, does it creep ahead or lurch?
  5. espi1
    espi1
    thanks okatoma. we figured out that the clutch wasn't disengaging because of all the customizing that was done from the pedal linkage to the clutch before we got the car. Pretty much the linkage is not giving us enough distance to disengage, so spome customizing will have to be done
