3 engines for sale. 300 I6 Ford, 272 Y-block Ford, 350 Oldsmobile
Discussion in 'Parts For Sale' started by flathead41ford, Apr 4, 2017.
  1. flathead41ford
    flathead41ford
    from Mentor OH
    City: Willoughby
    State: Ohio
    Price: $300 Each
    2 of these engines are newer than the cut off year. They can obviously be used in anything you want though. If the newer engines aren't aloud, just delete it and I'll just list the Y-block.
    Price is $300 OBO for each. Everything in each listing will be included with the engine.
    1955 Ford 272 Y block with 1956 Mercury/Tbird 292 heads. The engine is complete from air cleaner to pan with dual exhaust manifolds, 4 barrel carb, generator, starter and Mercury valve covers. Included with it is a 55 Ford passenger car 3 speed manual trans. This would spin about 3/4 of the way around when I removed it from my 55 Ford Customline in 2010. Good for a core or parts. I had a lot of interest in some of the parts off this like the heads, valve covers, manifolds, air cleaner and other misc parts but I'm not interested in separating.
    1996 4.9L (300 cubic inch) with a 2WD Mazda 5 speed out of an F150. This was my daily truck until it was totaled in 2011. The damn thing ran so good I couldn't let the engine go to the scrap yard. There was 198500 on the truck when totaled. All accessories are on the engine still as well as the serp. belt. The clutch, pressure plate and slave cylinder/throw out bearing have maybe 500 miles on them and new oil pan, gasket, water pump, belt tensioner, valve cover gasket, intake gasket, plugs, wires, cap, rotor, O2 sensors and lifter cover gasket have less than 5000 on them. It did have the typical skirt noise at first start up. I have the engine harness, MAF and EEC also out of the same truck. Could be converted to carb if you want by changing the intake. Already has split manifolds from the factory but you would have to plug the O2 holes or just leave them in, if you carb swapped of course.
    Third is a 1972 Oldsmobile 350 out of a 72 Cutlass. It is a long block with distributor, valve covers. balancer, fuel pump, water pump and oil pan. I don't think I would reuse the pumps, but they will save you on the core fee if you go with a reman that needs a core. Spins easy but don't know the history of it. 7A heads.
    These are located at my shop in Willoughby Ohio, 44094. Pick up only. Feel free to PM, call, text or email me with any questions. I can take any picture you want for the most part. I can send the pics through here, email or text. Some are tucked away pretty good still, but wont take long to get out. Bob 440-three four six-3333. Ford371j2@yahoo.com
    http://i307.photobucket.com/.../1955%20Ford.../stuff026.jpg
  2. flathead41ford
    flathead41ford
    from Mentor OH
  3. flathead41ford
    flathead41ford
    from Mentor OH
  4. flathead41ford
    flathead41ford
    from Mentor OH
  5. flathead41ford
    flathead41ford
    from Mentor OH
  6. flathead41ford
    flathead41ford
    from Mentor OH
  7. flathead41ford
    flathead41ford
    from Mentor OH
  8. flathead41ford
    flathead41ford
    from Mentor OH
    TTT. Open to offers
  9. flathead41ford
    flathead41ford
    from Mentor OH
  10. flathead41ford
    flathead41ford
    from Mentor OH
  11. flathead41ford
    flathead41ford
    from Mentor OH
  12. flathead41ford
    flathead41ford
    from Mentor OH
  13. flathead41ford
    flathead41ford
    from Mentor OH
    Ford 300 and 5 speed trans are sold. Y block and Olds still available.
  14. flathead41ford
    flathead41ford
    from Mentor OH
  15. flathead41ford
    flathead41ford
    from Mentor OH
  16. flathead41ford
    flathead41ford
    from Mentor OH
  17. flathead41ford
    flathead41ford
    from Mentor OH
  18. flathead41ford
    flathead41ford
    from Mentor OH
  19. flathead41ford
    flathead41ford
    from Mentor OH
  20. flathead41ford
    flathead41ford
    from Mentor OH
  21. flathead41ford
    flathead41ford
    from Mentor OH
  22. flathead41ford
    flathead41ford
    from Mentor OH
    Y-block sold. Just the 350 Olds left.
  23. flathead41ford
    flathead41ford
    from Mentor OH
    TTT, just the Olds 350
