I was going to build a 3x2 set up. My intake uses 2GC large carbs. The carbs i own now have the fuel inlet at the rear of the float bowl and hits the next carb. Does anyone make a 90 degree adapter that will give more clearance and bring the fuel in from the side of the bowl?
I'm building a 6x2 set up for my bbc using the large base 2g's. What I had to do was buy plugs for the fuel inlet and drill and tap them for 1/4" pipe. Then you can thead a 90 into them. I don't have any pics right now but I can post pics later if you want.
Buy the conversion setup to convert your carbs into correct looking side inlet and choke configurations.
I take it you have the large nut on your carb inlets. You can buy a thin carb inlet speedway, (ebay under rat rod carb). then go to any good fitting hyd. hose co. and get the 90 degree fittings jim
