Projects 292 Y block pricing
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Jun 25, 2020.
  1. hello.
    i have been offered a 292 y block complete with a stuck cylinder due to a blown gasket.
    couple of extra 2 barrel intakes, a fenton 3x2 intake,red headers,extra internal parts,chromed vc,moon valley cover,extra connecting rod and pistons.
    what would u price that if you were buying?
    thanks in advance
  2. I've seen rebuildable engines from $100 on up depending. If it's the early Y-up to '56, not much. If '57 or later, you want to research the block # and head #'s to see what you're getting. Need '57 or later dizzie and heads to get larger ports, posted heads, 2 bbl manifolds worth nothing, pistons may be worn. Go to Mummerts y-block site and do some research. I run a 292 in the 29. Heavier than a SBC or SBF, but the price was right and it gets along quick enough for me.
  3. jimmy six
    jimmy six
    Moon cover and Fenton manifold are worth the most. There are still a lot of 292’s out their. Sounds like your scouting to make a few bucks. The white metal is the cheapest to ship. Figure your $$$’s there.
    warbird1 likes this.
  4. 51504bat
    51504bat
    It sounds like it isn't something you have to have. In situations like that where I'm interested if the price is right so I can trade or sell off some of the parts to help finance a current project I ask the guy what he wants. I tell him I don't want to insult him with a figure less than he wants/has in mind. Sometimes you can reach a deal that way and other times not. JMO.
  5. So the earlier blocks aren't that sought after.
    Ok thank you
    I don't think the price he's asking leaves me room to make any money if I sell.
    I have a 59/60 292,It came with the 55 Vannete,It spinned but only a 1/4"a at time.
    I took it apart and found a few gallons of water in the pan but minimal rust in the cylinders....they look like they can be honed..
    I like Y blocks and I been wanting to have one built for either of my projects...
    So when this one popped up I figured it might be worth the risk...
    He wants 800.00
    Is the Fenton a decent intake?or is the value solely on the name brand.
    That's the way I look at things...
    They might have more value in a trade for a service or part than cash...
    People can get cash anywhere but vintage speed parts are getting scarced
  6. Budget36
    Budget36
    800 for a stuck Y-block? Well there's he extras I guess. I think you might be over spending, I'd price out the few good parts and think of the rest as scrap.
    Then again, I'm not hunting Y-blocks.
  7. Mr48chev
    I'd go along with around 100 for the core 292 unless it has the good 312 heads. There are a lot of runners floating around for not a whole lot. I'm not current on the intake and other pieces but I'd say that is where the actual value is.
    With the right set of pipes there are few engines in the world that sound better than a good Y block though.
  8. miker98038
    miker98038
    Unless it's a specific early casting (55 bird restoration) both heads or block they aren't worth much. The late heads (posted is better) are more and mentioned above. The Fenton manifold is not a performance part, just eye candy. 2 barrel manifolds aren't worth the shipping cost. I've got clean, turning 292's in storage, all with the generators, carbs, etc, late model truck motors, they're $300 tops.
    Heres the link to John Mummert's site on casting numbers and other info. Cracked heads are not unknown, so just the casting number is no guarantee. Core shifts often affect overbores much beyond 30 over stock for high performance applications. Ask me how I know.
    http://www.ford-y-block.com/technical.htm
  9. I bought a running '59 292 truck engine for $100 about a year ago, took it apart to check it out and found the block cracked at the main bearing areas. So I started looking for another one and ended up with a '57 292 that was stuck for $200. At Carlisle last weekend a guy was asking $200 for a 292 block freshly bored, a set of unposted "G" heads and crank. I guess what I'm saying is unless the other parts you could get with the deal are worth something $800 is on the high side.
  10. finn
    finn
    Runners go from $100-500 on some of the Facebook sites.
    Nonrunners go from free to $250.
    dana barlow likes this.
  11. As a perspective, in May I sold a running 1957 292 complete with all accessories and the transmission for $500.
  12. ahshoe
    ahshoe
    Just sold my running 272 without carb, dizzy, pulleys, brackets,gen ,starter and balancer, Ran good before I took those parts I listed off. Sold it for $250. Customer picked it up as shipping would kill any deal.
    egads and dana barlow like this.
  13. 41rodderz
    41rodderz
    from Oregon
    Good advice above. Either get the price down a lot or run. If you have to pay shipping run like Forest Gump.
  14. jimmy six
    jimmy six
    On the manifold Edelbrock is the best and Offenhauser the worst, $300-400 range for a Fenton. There is a complete ready to run with carbs, linkage, lines at the Bay asking over $1K. Not sure on the Moon cover but they list at $85 new now. Maybe $25-50 used. I’d only want a Fenton if I had their rocker covers and headers too. If headers were new you can check the price a would not want used ones since most will start rusting after use.
  15. Movinman
    Movinman
  16. The intake is worth around $300, unless it is cracked or broken. I bought a running 272 for $100 a couple of years ago.
    He also had a running 292 for $250. I do not see $800 in your proposed pile. It will cost more then a SBC to rebuild, about as much as a nailhead. I was lucky, new pistons and bearings, worn cam, lifters and rocker arms. Went with a supercharger cam and high lift rockers.
  17. customline3859
    customline3859
    I purchased my Red's headers for $350. I would check to make sure the welds are not broken anywhere, I've had to have mine repaired. I looked up prices on the fenton 3x2 intake on ebay a while back and found one being sold for close to $500. The fenton intake flows somewhere in the middle between the edelbrocks and the offenhausers. Ted Eaton did a 3x2 comparison a while back. Cheap chrome valve covers can be had for about $40. Would definitely check out ford-y-block.com and yblockguy.com, there is a ton of information there, casting numbers and everything. 292's can be bored up to .120" over, so the block should be salvageable, but those extra pistons may not do you any good. I think the asking price may be a little steep. Hope this helps.
  18. Like I said Im not in a hurry to have a running yblock..
    I have one that I took apart and it's sitting...
    I was thinking if I get it for cheaper I can start messing with them..
    b3052e169ad546829d4df8fa43d73d18.jpg 3e731a07ca614233bc1da77c37a64381.jpg d0c5a91a974548edac630fc03d697e2b.jpg 68ffd995622f4b95a2d241b888798fb8.jpg 71736ad8b7c145f5a549fe6c530bf84d.jpg 53cfc114b4bb40088d95d0ff3afd9db4.jpg
  19. What are the casting numbers/letters on the heads?
    customline3859 likes this.
  20. customline3859
    customline3859
    Check the casting number on the side of the rocker arms as well.
    egads likes this.
  21. I will get the numbers when I meet with the seller..he's out of town.
