Technical 292 Y-Block pistons size problem
Discussion in 'The Hokey Ass Message Board' started by Maniut, May 29, 2017.
  1. Maniut
    Maniut
    from Poland
    Hi everyone
    I have a problem with finding correct size of pistons for my first engine rebuild. It's a 292 Ford Y-block, I need .020" oversize set of pistons and rings, but I found that there is only 0.30" on ebay , and .macsautoparts.com is the only place with .020" but they are very pricey! Could anyone let me know if there is somewhere .020" available? or should I overbore my block to .030"?
    thank you in advance
    Mariusz .
  2. I am not a y block guy but my thought is what size bore will give you 312". That would be a stock size bore.
    Sent from my SM-G900V using The H.A.M.B. mobile app
    Maniut likes this.
  3. BOBCRMAN
    BOBCRMAN
    from Holly
    Why are you so set on .020" pistons? If the block has to be bored any ways, go with the cheapest, available piston.. .030" is a more common oversize. That's why the availability/cost difference
    If your block is already .020". Then find a shop that has a Ck-10 or CV-616 Sunnen or equivalent honing machine.. A decent shop, will then only charge for a hone job.
    loudbang and Maniut like this.
  4. sunbeam
    sunbeam
    312 bore is 3.8 or .050 over 292 Ford changed the rod lenght to account for the add stroke. MY experance it almost always takes more to clean it up than you first thought go with the .030 pistons.
    loudbang, Maniut and dirt t like this.
  5. Maniut likes this.
  6. squirrel
    030 is the normal first overbore. And sometimes you need to bore the block first to see what size it needs....I did a 235 chevy that was standard size, and needed to go .060 to clean it up!
    BigChief, 302GMC and Maniut like this.
  7. RMONTY
    RMONTY
    That's what happened with my 235. The pistons had been knurled and even though it it had never been bored they had to punch it .060 to get everything squared up.
    Maniut likes this.
  8. Maniut
    Maniut
    from Poland
    Thank you all for detailed comments, my block has 3.75" bore, it's a factory size, mechanicans told me that 0.020" should be enough, and this is why I am looking for this size. My block is not overbored yet, it's waiting in the line, until I get the proper pistons. I can talk to them and said that 0.030 should be ok.:cool:
  9. CNC-Dude
    CNC-Dude
    Most common American engine oversizes are .030", .040" and .060". There have been a few odd rare occasions through the years that a .020" oversize piston was common for certain engines, but not all of them. Just because the block can clean up quickly at a .010" or .020" oversize, doesn't mean that a piston can be obtained for it unless you go custom.
  10. squirrel
    If .020 is the minimum it needs to clean it up, you will have him bore it .030" simply because that's what size pistons you can buy. This is totally normal procedure.
    If you're worried about future overbores....don't....it won't get driven enough to wear it out so much that it ever needs another overbore.
    leadsled and Maniut like this.
  11. vickckik
    vickckik
    They probably only have .030 and larger pistons but take a look at Northern Auto. A .030 overbore was the usual remedy if oversize rings and knurling wouldn't stop the Y block smokescreen. Back in the 60s, if you had a 272, it got punched out to accept 292 pistons.
  12. sunbeam
    sunbeam
    Boring a block is kind of a catch22 You need to bore it to find what over size but you need the pistons because of the variance between pistons in a set. A customer brought a set of name brand 400 pistons that varied .005
    Maniut likes this.
  13. squirrel
    bore it to the standard oversize that will clean up, buy the pistons, then hone it to final size to fit the pistons.
    BigChief, loudbang and Maniut like this.
  14. Maniut
    Maniut
    from Poland
    I found out the Northern auto Parts have in stock standard size, and .030" only, but in a Ford 292 1955-1964 Block Kit you can choose .020", it's strange, I would buy a whole kit If I knew it before, but I already bought a gasket set :/ , I am confusedo_O:cool:
    But most of you told me to buy .030", so I think I will stick with this size.
  15. sunbeam
    sunbeam
    Northern will adjust will adjust price and leave out the gaskets. I have used their kits all name brand parts.
  16. BOBCRMAN
    BOBCRMAN
    from Holly
    Yes, I buy many kits from them. They can build about any reasonable variation on kits.
  17. blackrat40
    blackrat40
    I worked in a rebuild shop for years (early 60's). Don't risk buying .020 pistons & rings. Go with .030.
    Cylinders often have a taper wear pattern. .020 might or might not clean up all the cylinders.
    Forbes is right. Final honing (which MUST be done) will achieve correct piston fit.
    Maniut and loudbang like this.
  18. Maniut
    Maniut
    from Poland
    adjust sounds great for me:cool:
  19. Maniut
    Maniut
    from Poland
    you guys are great, I wasn't expected so many important comments within few hours! I have never received so many and so fast on facebook's car forums or ebay, thanks a lot for help!:D:cool:
  20. Maniut
    Maniut
    from Poland
    wow, early 60's, you must be right!:cool:
  21. robtlor
    robtlor
    from Lincoln NE
    Rock auto has .030 pistons. 32 bucks each for the 292
  22. squirrel
    When I overhauled my 292, it had enough wear in the bores that any machine shop would tell me it needed to be rebored. But I know that with somewhere around .005" wear in the bores, I could just replace the rings, and the engine would work fine, and last probably 20,000 to 40,000 miles before beginning to use oil, lose compression, etc. So, I just honed it and put in new standard size rings. I put about 5,000 miles on the car before I sold it, and I really doubt it will get another 5,000 miles use in it's lifetime (no one seems to drive old cars any more). Surprisingly, it would take over 3,000 miles to use a quart of oil, which is excellent for a 57 year old engine!
    So...think about whether or not you really need to rebore the engine and get new pistons.
    Maniut likes this.
  23. Maniut
    Maniut
    from Poland
    Two of my pistons are damaged, and all of the rings are already broken, in one skirt you can feel concave upon your finger, so I think it has to be rebored.
  24. squirrel
    Yes, it probably does. Now we know.
    Maniut likes this.
  25. Maniut
    Maniut
    from Poland
    I am about to buy 292 engine rebuild kit from Northern Auto Parts, I found out that they have .020" and .030" pistons available, I know you all told me to buy .030", but I need a final advice from all of you please:cool:
  26. squirrel
    If the machinist is confident it will clean up at .020 and the price is similar, then I guess it is up to you.
    Johnny Gee likes this.
  27. sunbeam
    sunbeam
    292s had thick walls If you bore .030 and need to rebuild again theres .060 then you can go oversize 312 pistons. I ran a 292 that was .150 over to use 318 poly pistons It was a late block and sonic tested.
    Maniut likes this.
  28. squirrel
    also old blocks don't always have the bores perfectly perpendicular to the deck, and if the boring machine locates off the deck surface, it might miss the end of the bore. There are several reasons why the normal first overbore is .030 instead of .020
    BigChief and Maniut like this.
  29. Maniut
    Maniut
    from Poland
    I am almost sure of .030", any more comments from others?:D
