Projects 292 valves
Discussion in 'The Hokey Ass Message Board' started by 292newbie, Jan 26, 2020.
  1. 292newbie
    292newbie
    Hello everyone, i need some guidance. I'm building a 292 inline 6.. where can I find flat top pistons and what brand do you prefer... Also where could someone find 1.94 inake valve (same motor).
  2. squirrel
    isn't the valve the same as the small block V8 valve?
    I don't know where to find flat top pistons, what compression are you aiming for? I'm putting dished pistons in the 292 I'm thinking about putting together soon.
  3. karl share
    karl share
    Federal Mogul made flat top pistons for 292 chev six, we used them in our hyster fork lift when motor was rebuilt.
  4. Gofannon
    Gofannon
  5. Hud I
    Hud I
    from Tennessee
    The pistons that Karl are referring to are propane pistons. They are the cheaper way to flat tops. The other way is the custom piston makers. They are not so cheap. L Hud
  6. With todays gas I wouldn't use flat top pistons. A thin head gasket and possibly mill the head will get you all the compression ratio you can stand. A 292 has plenty of HP and tremendous torque. Its not a high RPM engine. The will certainly pull and haul a heavy load. and will use as much fuel as a big block doing it.
    Truckdoctor Andy likes this.
  7. squirrel
    But are they still in production? If not, then you'll probably have to get custom pistons.
    I have Ross pistons in my Hemi, they make good stuff, although you get to pay good money for it.
  8. Hud I
    Hud I
    from Tennessee
    The easiest way to wake up a 292 is put a 194 head on it. The 194 head is getting harder to find.
  9. Joe H
    Joe H
    The 194 head will raise the compression, but the ports are so bad in it, you will need a bunch of porting to use the raised compression.
  10. Casual 6
    Casual 6
    from Great NW
  11. 292newbie
    292newbie
    I'm aiming for 10.5:1 or 11:1 compression. I have 194 head, 250 head and a 292 head... but no one has any information on cfm on 6 cylinder heads.. I'm waiting low end torque. So I'm wanting .060 bore. Flat piston. Roller rockers, but not sure on which head and valves
  12. 292newbie
    292newbie
    I'm looking into Howard's hydraulic flat tappet cams. Just need to decide on what rpm range I'm wanting
  13. Hud I
    Hud I
    from Tennessee
    If you are wanting torque and a good street cam. The 270 hyd. RV cam is the most common one . Has plenty of torque and will run also.
  14. Ebbsspeed
    Ebbsspeed
    Sounds like your RPM range has already been decided. The 194 head doesn't breathe well, but doesn't have to at the bottom end.
  15. Joe H
    Joe H
    here is a PDF with air flow numbers.
  16. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    I always ask my machinist his prices on parts....
    squirrel likes this.
