Hot Rods 292 chevy flexplate
Discussion in 'The Hokey Ass Message Board' started by scoop, Dec 2, 2015.
  1. scoop
    scoop
    Is there any difference between a flexplate for small block Chevy and a 292 six,beside the bolt holes being bigger and more dowel holes?I got a small block flex plate drilled the holes larger and added a dowel hole.It makes deafening noise when I turn it over,put in 3 shims didn't help.
  2. squirrel
    did you check the distance between the flexplate gear teeth, and the starter motor shaft? should be 1/8", you can measure it with a 1/8" drill rod or allen wrench.
    they're all 168 tooth 14" diameter.
  3. RJC
    RJC
    from hope bc
    yes 292,s are xternely balanced ,like a 454 also have 1/2 inck crankholes
  4. squirrel
    never seen one externally balanced, are you sure about that?
  5. scoop
    scoop
    Internally balanced.
