I started to put my drip rails on the car. I filled the original spots above the qtr windows. The above the door fillers i made. I used the position on the qtrs to start my drip rails and then down to the front. I'm asking if it looks right or close enough? Thanks guys.
I don't think they are positioned correctly. Am I the only one to see it? Look at the pics of this coupe. Very different position. Even on this wacked out body. Yours start to rise too high about half way along the door. Should be almost a straight shot back to the side window.
That's kinda what i thought but i followed the nail hole on the qtrs and went from there to the front. Right at the point of the qtr and the roof panel there in the center of where the nails would be.
Don't know if there is a difference but my 31's drip rail is 1/8 up off the top of the front of the door and 1/4 at the back of the door (hope that's not too confusing).... ......jack
I think they look good. Just my opinion but I think model A's look strange without drip rails. Glad you took the time to put them back on.
I think they look OK. They are positioned wrong, but it only matters to you, so if your happy, then all is good. If you do decide to take them off to reposition them you should consider rosette welds from the inside....lots less finish work
Still look a little high to me, but whatever you like. Coupe below is a '30, the drip rails hug the top of the doors.
The second set of pics look better. I personally like them close the the original location. Its hard to tell how it will look when there is color on the car. At the end of the day, where do you like them best, Its your car.
I think the 30-31 are closer to the doors. The stamping in the qtr above the window is where they should be right, where the nail holes are? I started there and the proceeded forward. The last pic is about where i'm going to leave them. I see how the 30-31 hug the doors closer. Any body got good pics of 28-29's?
I agree that there is something different going on. You have more space above the door than on my two 29 coupes. Are your doors maybe chopped a tad more than the body?
If you look at the pic of Scrap Metal and then look at mine, i think i'm pretty close. I think it's the angle and closeness of my pic. I'm happy. Thanks Guys'.
Mine have a 1 1/4" gap from the door top to the bottom of the drip rail.. Measurements can vary if there is any door sagging, however...
