Hot Rods 283 fuel needs
Discussion in 'The Hokey Ass Message Board' started by khead47, Jul 27, 2020.
  1. khead47
    khead47
    Hey Hambers . I will finally be able to get to the DMV tomorrow to get my 47 Coupe legal. It has a stock 1966 283 2bbl. My fuel gage reads 3/4 full. PO said he used additives to the gas. I want to fill it up on the maiden voyage tomorrow. So, my question is should I be concerned with valve seat recession ? Marvel Mystery oil ? Or should I just drive it ? 20200601_181811(1) (1).jpeg
    Jalopy Joker likes this.
  2. olscrounger
    olscrounger
    a little MM won't hurt--drive it!
    1oldtimer likes this.
  3. flatford39
    flatford39
    Have you driven it anywhere?? I would at least do some laps around the neighborhood to shake it out prior to your drive to the dmv or did I not understand your question.
  4. Drive it
    Put a million miles on non hardned seats.
    Put them in my last build but it’s a bus.
  5. khead47
    khead47
    flatford39. Not taking the Coupe to the SOS. I will drive it around the neighborhood before any longer trips. My question is concerning many reports in the early 70s showing severe valve seat recession in engines with non hardened seats. The 283 in my car will be driven like the old man that I am. I have ran many pre 70s cars on no lead with no issues. 20200601_110752 (1).jpeg
  6. jimmy six
    jimmy six
    I’ve put 10,000 miles on my y block 56 and for my peace of mind add 1oz of Marine Sta-bil with every tank and it has the original valve seats. There is a lot of info on the web and here on using today’s gasoline. Most recent I’ve read not to use any higher octane than needed.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The likelihood of seeing any valve seat recession in your lifetime is remote. If you were doing high speed, heavy footed driving the recession could be more significant after many thousands of miles but for your driving schedule don't worry about it. Enjoy
    olscrounger likes this.
  8. squirrel
    Drive it. If it gives you problems, then do something about it. As they all say...you'll be fine.
  9. Ericnova72
    Ericnova72
    from Michigan
    Takes a lot of heat to cause seat and valve face wear and recession.... heavy loads, trailer towing, sustained high speed driving(high engine rpm 4000+ constant).
    Ordinary passenger car/ light duty truck use it is almost non-existent.
    Lloyd's paint & glass likes this.
  10. khead47
    khead47
    Thanks all. That is what I thought. If it ain't broke........................
  11. SEAAIRE354
    SEAAIRE354
    If the engine is is original from 66 the seats will be work hardened from the leaded fuel and as long as the guides aren’t worn and it’s tuned correctly you should have no problems. One of the problems is when guys grind the seats to much and make them to wide. And I’m with squirrel. Drive it and deal with it if there’s a problem. Then I would recommend hardened exhaust seats. And I have seen a lot of pounded out sunken seats and as said mostly heavy trucks or bad valve jobs.
  12. southcross2631
    southcross2631
    Put some 87 octane in it and run it. Lots of stations are selling non ethanol gas here in tn.
    I don't know about up there.
  13. Belle53
    Belle53
    don't worry about it , valve seat recession on a SBC is not a problem valve003.jpg
  14. 6sally6
    6sally6
    X-2 ^^^^^^^^^^^^
    6sally6
  15. 4 pedals
    4 pedals
    from Nor Cal
    Top off the tank with fresh gas and take it for a ride! By 66, the 283 was the low performance "dog" motor, don't need any additives, and if it wears the seats it will take thousands of miles. Run it and smile!
    Devin
  16. I use a little MMM, for me at least it aids keeping the fuel from turning (kind of like stabilizer, but smells better).
