Technical 283 block ID
Discussion in 'Traditional Hot Rods' started by edisonfire, Jan 7, 2020.
  1. edisonfire
    edisonfire
    I'm having a tough time figuring out what block I have. The casting number is 3789935 which I believe is 58-64, the date code is E172, so that would be 62. The engine ID is F05I8D and this is where I get thrown off, I can't seem to find any sort of information on that type of engine ID. Is there somewhere else I should be checking for numbers to help identify?
  2. Lloyd's paint & glass
  3. squirrel
    yeah, pretty much a 2bbl 283 with powerglide. The boringest V8 engine you could get from Chevy back then.
    F means Flint engine plant
    0518 means May 18 assembly date
    D means it's a 2bbl 283 with PG
    mgtstumpy and Desoto291Hemi like this.
  4. edisonfire
    edisonfire
    Thanks, guys. It's going in my 1927 T so it should be enough engine for that, as boring as it may be.
    mgtstumpy and squirrel like this.
  5. Lol,,,I was thinking when I read this,,,,,”just wait until Squirrel gets here,,,he will know “.
    I am pretty confident that he can tell what the guys had for lunch that day also .
    He is Spooky accurate usually,,,but the man knows !
    Tommy
    Old wolf likes this.
  6. In relation to power and hp maybe considered boring but very economical . I had an early Nova with 283 two bbl. 4 speed and 3:08 gears. 31.2 mpg on a trip. Two squirts on the gas and touch the key and the engine was purring . I left the The LT-1 , 4:10 geared other Nova sit home while the 283 was my easy driver. The lil 283 sbc sporting 3 2s , some finned Corvette valve covers looks good in any rod. jmo.
  7. At 195hp, it's not as boring as most of the engines on that list...
  8. squirrel
    Put it next to a Fuelie 327, and it's pretty boring.
    Desoto291Hemi and mgtstumpy like this.
  9. lippy
    lippy
    from Ks
    To make it worse, I think they were 170 hp in late 62 lol. Lippy
  10. squirrel
    The block isn't what makes power, anyways. In a hot rod, the stamped numbers really don't mean anything. But now you know what it came from.
    edisonfire and Desoto291Hemi like this.
