Projects 28 model A Coupe build--first time
Discussion in 'The Hokey Ass Message Board' started by reyn, Jan 25, 2015.
  1. waxhead
    waxhead
    from West Oz
    x2, nice work on the visor.
  2. catdad49
    catdad49
  3. NICE WORK! What did you do before you retired?
  4. Wow, hit that one right out of the park on the first swing! Visor looks great!
  5. Binger
    Binger
    from wyoming
    Thanks! I was surprised how much fun the t-5 made driving my car. I like the visor work a lot. I wouldn’t have thought of making a shorter visor to go along with a chop.
  6. reyn
    reyn
    Seemed to get more done when working full time than now that I am retired. Keep plugging away. It will get done. Needed a break from bodywork. Installed the engine and decided to get a lot of little things done. Moved the radiator ahead 1 inch for fan clearance.
    Made a new steering column using extra 60 impala parts and 37 ford steering wheel.
    314.JPG 315.JPG 316.JPG 317.JPG 318.JPG 319.JPG 320.JPG 321.JPG 322.JPG Then made a horn ring
    323.JPG 324.JPG 325.JPG Wanted cowl steering, but decided on reversed corvair on the frame rail
    337.JPG 338.JPG 339.JPG 340.JPG Needed a small heater to fit between the fuse panel and gas pedal. Used a 33 dodge core that I salvaged. 326.JPG 327.JPG 328.JPG 329.JPG 330.JPG
    oliver westlund likes this.
  7. reyn
    reyn
    Installed shocks and headlights
    Then floorboards
    349.JPG 350.JPG 351.JPG 352.JPG 353.JPG 355.JPG 356.JPG 357.JPG 360.JPG 362.JPG 363.JPG 364.JPG
  8. reyn
    reyn
    Then clutch and brake switch
    and finally throttle linkage.
    This build is taking so long and I don't know how much interest is out there. I'll keep plugging away and see how it goes.
  9. 1-SHOT
    1-SHOT
    from Denton
    I like the way you mounted your return springs on the brake & clutch pedals. The sun visor is a work of art really like it.
    Your ability to build something out of parts and pieces is the true sign of a craftsman.
    I was fortunate enough to be mentored by a body man who worked during the Great Depression and WW II and they had to use whatever they could scrounge up to repair cars he was a true craftsman his work habits helped me immensely.
    Still watching from Texas, Frank
    brEad likes this.
  10. reyn
    reyn
    Thank you so much for your comments. Every day is a learning day. Can't be scared of making mistakes or nothing would get done.
    dodgedifferent2, wackdaddy and brad2v like this.
  11. 1-SHOT
    1-SHOT
    from Denton
    My grand son 8 1/2 told me he could not do anything right and was crying. I took him out to the shop and showed him the scrap barrel and told him that we're all my mistakes and showed him the finished part and told him mistakes are how you learn to do it the right way. His attitude immediately changed to the positive and he said, PaPa you do learn from your mistakes and he was more determined to make it work and he finely won the game he was playing. Thanks again for shareing Frank
    Budget36, brEad and catdad49 like this.
  12. Nice work! I like your fab on the heater - it looks great!
  13. oldsman41
    oldsman41
    Killer work guy
  14. brad2v
    brad2v
    Love the heater, well done.
  15. Straight Axle Guy
    Straight Axle Guy
    Extremely nice workmanship! There is such a great and fun feeling building them and then driving them!! Great work!
  16. goldmountain
    goldmountain
    Do you have any 1-800 street rod parts in this build other than the Walker rad? Your fabrication skills are way over the top.
  17. catdad49
    catdad49
    I think you are going Great. Any progress is Still progress. Is your wife missing the pot yet?! That looks fantastic (along with the rest of it). Keep sharing, you'll be done before you know it.
  18. reyn
    reyn
    Thank you all for your comments. It' a fun time building something out of nothing and saving money at the same time. Love the time in the shop. Was trying to go cheaper with this build, but it adds up in a hurry.
  19. Mike Colemire
    Mike Colemire
    You've got a lot of nice fab work but that heater is just amazing.
  20. Fry
    Fry
    from SK, Canada
    Great work! Neat to see fellow Saskatchewanians.
    wackdaddy likes this.
  21. patzfab
    patzfab
    from Canada
    You are a true craftsman. Your work is proof of your dedication to get it done. I also like to make everything I can, but your skills and knowledge of how things work are outstanding.
    The drive on the bead roller, I will be copying that!
    Your frame rails are great, I already have the side rails plasma cut, and now have to finish the flanges, how you did it is way better than what I had in mind.
  22. reyn
    reyn
    Thanks It's nice to make use of what is on hand
  23. reyn
    reyn
    Been following your build also. Impressive. Lots of great ideas.
  24. reyn
    reyn
    Thank you very much
  25. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Only suggestion is, Don't tell the wife about the pot used for the heater....
    Impressive work sir... definitely a good home built hotrod....
  26. Still following from KC, too!
  27. Tim_with_a_T
    Tim_with_a_T
    That heater (as others have said) is a really cool part of your build. Nice job.
  28. DDDenny
    Quite crafty!
    And finally, someone else that sees the value of a shorty steering column with the first joint on the interior side of the firewall.
  29. reyn
    reyn
    Took the rear end housing apart planning to make an emergency brake disc on the pinion yoke but decided it was too much work after taking a 3.89 rear apart. Thought I may as well rebuild it and install the trac loc I bought for it. Waiting for pinion shims. 377.JPG 378.JPG 379.JPG
    Meanwhile I wanted to get the emergency brakes done. I love the old style handle and thought I would try making one.
    Now to try and mount it. Since there will be a trac loc I am going to use a cable only on the passenger side. Should make it a little easier.
  30. Damn I like this build
