28 Coupe Build
Discussion in 'Traditional Hot Rods' started by 51box, Jan 16, 2016.
  1. wackdaddy
    wackdaddy
    Very impressive ... nice work!
    51box likes this.
  2. Amazing job on the interior! You could start a new career.
    51box and loudbang like this.
  3. Question on your interior panels.... the panel not the vinyl, the curved pieces in the rear corners. What material is that? Cardboard or some kind of plastic? Where did you source it? How did you curve or mold it? Thanks!
    Walt
    Outsiders CC
  4. 51box
    51box
    from MA
    The panel material is called PVC foam board, I bought it at a local plastic supply place. It’s metric but is about 1/8” thick 4’x8’ sheet around $30. Used an adjustable heat gun to warm it up to form it around the corners, just don’t get it too hot or it will deform.
  5. 51box
    51box
    from MA
    Also something I found while researching interior work that saves a bunch of time is using clear vinyl to make your patterns. It lets you lay out edges and mounting holes etc. exactly where they need to be.
  6. Killer build. Nit picky details, well worth it. You obviously .. iron your underwear. :) Such a kick*ss coupe !!
    Outback, 51box and loudbang like this.
  7. Malcolm
    Malcolm
    from Nebraska
    VERY nice job on the interior!
  8. scoob_daddy
    scoob_daddy
    from Georgia
    that's a killer machine, and now a huge inspiration for my 29 coupe on 32 rails!
