Projects 28 Closed Cab AV8 project
Discussion in 'The Hokey Ass Message Board' started by 55styleliner, Feb 4, 2017.
  1. 55styleliner
    55styleliner
    IMG_3312.JPG IMG_3314.JPG IMG_3318.JPG Here is how it started 2 months ago. Bone stock older resto on a very solid old truck. 100% Henry steel
    osage orange likes this.
  2. 55styleliner
    55styleliner
    IMG_3350.JPG Added '35 Wires
  3. 55styleliner
    55styleliner
    IMG_0080.JPG Split '40 Bones with the end sculpted IMG_0013.JPG Started collecting and prepping pieces. Got a great deal on an 8BA
    2935ford, osage orange and walter like this.
  4. 55styleliner
    55styleliner
    IMG_0082.JPG C-notched the front of the frame IMG_0081.JPG Modified the front crossmember to lower it an inch
  5. 55styleliner
    55styleliner
    IMG_0089.JPG Front ride height dialed in used a 36 front axle with a 2" drop Posies spring. Got the wheels powder coated black IMG_0090.JPG Engine mocked into place. I don't have to cut the firewall if I use an electric fan. I think I'm taking that route.
    davweed34, osage orange and ROCKER77 like this.
  6. 55styleliner
    55styleliner
    Does a 10" clutch use the same flywheel bolt pattern as a 9"? The motor has a 9" clutch on it and I need a 1-1/16 10 spline disc to fit my F150 RTS transmission. I can't seem to find a 9" disc with that spline. I can redrill the flywheel if I need to, just curious if anyone knows.
  7. trad27
    trad27
    Gotta admit, I cringed a little at how clean that truck is to cut up but you heading in The right direction. Gotta love AV8's. Keep us posted. What are your plans for the old banger dizzy...
    ROCKER77 likes this.
  8. 55styleliner
    55styleliner
    I have
    sold the whole drivetrain to a good friend.
  9. Jalopy Joker
    Jalopy Joker
  10. 55styleliner
    55styleliner
    IMG_0093.JPG I am using a shortened F100 steering box. I cut it off, cut a new seal counterbore and made a new flange. IMG_0094.JPG I have the box so tight that I had to notch the frame a little. I need every 1/4" I can get! IMG_0095.JPG The finished box.
  11. 55styleliner
    55styleliner
    Lengthening the frame for the 40 rear axle.
    GASSERBOB likes this.
  12. 55styleliner
    55styleliner
  13. 55styleliner
    55styleliner
    40 rear axle cleaned and painted. Reverse eye model A spring installed. Still need to shorten the radius rods and make a torque arm.
  14. 55styleliner
    55styleliner
    Firewall filled and painted.
    GASSERBOB and spurgeonforge like this.
  15. 55styleliner
    55styleliner
    Engine cleaned and painted. Heads blasted and new gaskets and studs installed. New Powermaster alternator and 9Super7 carbs. Tranny painted too.
    GASSERBOB and ROCKER77 like this.
  16. What adapter for the trans?
  17. 55styleliner
    55styleliner
    It is from Model Engineering. Nice piece but was about a 6 week wait to get it.
  18. Thank you.
  19. 55styleliner
    55styleliner
    I started with the Speedway Economy headers and straightened out the back tube for more steering box clearance. Got the clutch all together and transmission mounted.
  20. 55styleliner
    55styleliner
    Engine in place. Permanently I hope.
  21. 55styleliner
    55styleliner
  22. 55styleliner
    55styleliner
    Back on 4 wheels. Nice low stance.
    OFT, walter and osage orange like this.
  23. 55styleliner
    55styleliner
  24. Looking good!!!! Be sure your wheels don't rub the fenders, especially the front wheels when turning (don't ask how I know to check for this).
    Charlie Stephens
    55styleliner likes this.
  25. spurgeonforge
    spurgeonforge
  26. 55styleliner
    55styleliner
    I have the rear suspension pretty well done except for the torque arm. Thanks for all the ideas here on the HAMB!!!!
    55Deso likes this.
  27. 55styleliner
    55styleliner
    Look for me and the truck at Round Up on April 7th!
  28. 55styleliner
    55styleliner
    Front shock mounts
  29. 55styleliner
    55styleliner
    Clutch linkage and parking brake done
  30. 55styleliner
    55styleliner
    Rear suspension done
