Finally got some room to throw some parts together for next pending project. 28 hiboy roadster on stock shape chassis. Are there any books to buy or info online about engine placement in chassis ? I have read a little about different water pumps etc for clearance issues . I want to run a radiator in its stock place behind a stock 28 shell and not cut the firewall if possible. And I need to know where engine goes, re height and potential steering box/ exhaust clearance issues etc. Will be RHD . Have a 21 stud motor to start with the mock up .
First would the Bishop-Tardel book,and Nostalgia by Ron HollaranMotor mounts 3" back from radiator mounting hole to forward edge of mount.
There is NEVER a standard measurement for a hot rod engine install. Every hot rod has some different components. If somebody tells you a measurement, mock it up and check for yourself first. Mock/block/bolt up ALL your parts before welding anything in. Especially all us northerners trying to give you info for your RHD install. We have no idear what your backwards steering boxes and pedals will measure up to be.
http://www.jalopyjournal.com/forum/showthread.php?t=490850&highlight=bishop http://www.amazon.com/Build-Traditional-Ford-Motorbooks-Workshop/dp/0760309000 Sure there are some theories on conflicting information , but this book is a heck of a start and a good read.
