Technical 270 hemi distributor
Discussion in 'The Hokey Ass Message Board' started by Alexanderkustoms55, Sep 21, 2018.
  1. Does any one know what aftermarket distributor I can use for my 1955 hemi 270 motor.. I was looking at a few different ones on eBay but they where all for hemi 318. Any help would be greatly appreciated..
    Thank you
    Rob
  2. Reds 29
    Reds 29
    I used the electronic distributor from a 273-340 from Mopar. Fit right in, had to get a box.
  3. Bandit Billy
    Bandit Billy
    Hot Heads sells MSD drop in units. Plug n play. I just bought one.
    This says it’s only for 1964-78 273-318 motors will this work?
  5. Bandit Billy
    Bandit Billy
    I talked to several guys in the know and the alteration sounds simple to make that 318 distributor work.
    I went MSD because I have them in 3 dailies and they haven't failed me.
  6. Do you have a part number or can you point me to exactly what you used? Thank you again
  7. Bandit Billy
    Bandit Billy
    Google hot heads research or hot heads hemi. They are amazing what they offer. Caution, you may end up buying a lot more than you intended. I did! :cool:
    Mine is a 330 Desoto. I was afraid I wouldn't fund parts for it. I was pleasantly surprised.
  8. Bandit Billy
    Bandit Billy
    That was funny, spell check put "fund" rather than "find". Both apply.
  9. Andy
    Andy
    You can buy everthing needed from Summit. You need a resister, wiring harness, amplifier, and the distributer. The dist. installs with no modifications. I have one in my 241.
    I found this on eBay and it looks like it fits the hemi small block.. but it does not specifically say it fits the 270...
  11. Andy
    Andy
    Yes, It will work fine . Just hook it up and go.
  12. tubman
    tubman
    If you're after that "classic" look (you are on the H.A.M.B. after all), there are some old Mallory "flattops" out there. I have been able to find two over the last couple of years. I would expect that even if you found one, it would be substantially more than Jeg's and Summit are asking for their small block Mopar units.
    One last thing; the originals were pretty good units if they were kept in good shape, and they had dual points from the factory. I have an extra if you can't find anything else.
  13. katyfattrodder
    katyfattrodder
    the above setup is what I have in my 270
  14. Work In Progress
    Work In Progress
    You can run a late 70’s GM HEI module instead of that box and troublesome resistor. Better spark and easier to hide.
