259 (VT338 engine ID) engine with 270 hemi heads (1554132 casting) and std bore high compression pistons (Forged True brand based on the marking). The 259 block will need to be bored out to std270 bore to use the pistons and make it a 270. I have cleaned the outside and sonic checked the cylinders walls to ensure the std bore 270 pistons would work..it appears OK based on these measurements. It will require a complete rebuild of course. It is located in Brodhead, WI. I can secure to a pallet and ship via SpeeDee or Fastenal. $1650 Contact via PM. Will consider partial trades for 315/325 engines or parts.
