'27 T Coupe Build Seattle
Discussion in 'The Hokey Ass Message Board' started by RDRACER, Nov 8, 2011.
  1. 60 Belair
    60 Belair
    Hey your T looks like it coming along, great keep up the good work!
  2. pincher
    pincher
    from Saginaw
    I really like your HOT ROD , the back panell below deck lid looks good ,something different. What kind of tail lights are you thinking about? I am also building a 27 T.almost ready for paint.Good luck with your build, and keep us posted..........PINCHER
  3. fiftyv8
    fiftyv8
    from CO & WA
    Nice work on the frame, it will provide me with a few helpful ideas.
  4. Lots of cool fab work! Your off to a great start!
  5. CGkidd
    CGkidd
    Any updates to this?
  6. gilles d
    gilles d
    from winnipeg
  7. moses
    moses
    rite on too kool...jeffrey
  8. CGkidd
    CGkidd
    Any updates on this ride?
  9. DERPR30
    DERPR30
    from HARVEY LA
    Here is a pic of my 27 coupe
      50.5 KB
    chryslerfan55 and NewGuyOldFord like this.
  10. RDRACER
    RDRACER
    from Seattle
  11. RDRACER
    RDRACER
    from Seattle
    After four years of driving this sweet little "half" coupe I figured that is was time to come back and update with a few "finished" (if ever) pics.
    If anyone is interested here are the basic build specs:
    1927 Ford Model T Coupe Body – 8” top chop and 4” off bottom.
    1927 Ford Title
    1927 Washington license plate
    Custom “inner body” frame
    Custom main frame
    1953 Ford ½ T truck steering box
    Bell chrome 4” drop front axle
    Dropped steering arms
    1940 Ford front brakes
    1956 Chevy rear end 4:10 ratio
    1948 Ford pick-up 3 speed top loader trans with custom open driveshaft
    Hydraulic clutch with 10-1/2” Ford truck clutch
    Pozi front spring – split wishbones – tube shocks
    Coil over rear suspension with ladder bars
    8 gallon fuel tank
    Pro built 3 row radiator with electric fan
    1935 Ford 16” front rims with new 500/16” rubber
    11” rear alloy rims with Mickey Thompson P315/60 R15 ET street slicks
    12 volt electrical system with twin Optima sealed batteries
    ENGINE:
    1952 8BA Ford block
    1949 Merc crankshaft – 4” stroke – now approximately 265 cu. In.
    Original Edmunds custom aluminum heads – 8:1 compression
    Original Edelbrock 3 2bbl manifold SU359
    3 Genuine 97 Ford carbs
    1947 Ford water pumps
    Genuine Johnson adjustable lifters
    SU1R Isky grind cam (Delta Cams/Tacoma)
    Heavy duty valve springs
    Aluminum cam gear
    1942-45 points distributor
  12. CGkidd
    CGkidd
  13. 26hotrod
    26hotrod
    from landis n c
    Just found this thread and glad I did. Looks like you did a great job on a hot rod you will enjoy for a long time.I have a 26 coupe Ihave had for 21 yrs and still enjoy it. The chop on mine is similar to yours. If you can round up a copy of Rodaction magazine, July,1985 issue,pg 26 you can see it. Happy motoring and keep us posted on any changes you make...............
