Projects '27 Roadster Build.
Discussion in 'Traditional Hot Rods' started by Texas36, Aug 29, 2015.
  1. Thank you. No I havent been there but Im sort of familiar with the area.
  2. Today was a humid miserable day. Heat index of 103 here in coastal Texas and about 10 degrees hotter in my shop but I managed to finally finish the '32 crossmember and get it installed in the frame. Also hung the rear end to get my measurement to cut the torque tube before I ran out of energy. [​IMG][​IMG][​IMG][​IMG]
  3. TexasSpeed
    TexasSpeed
    Texas36 likes this.
  4. Thanks Matt. We have a few dimensions we need to tweak a little, but thinking about maybe making some DIY kits for people to build that wont be nearly as expensive as an already assembled crossmember.
    Tim and Nailhead A-V8 like this.
  5. So Ive read that Lincoln front backing plates can be used with a '36 wide five drum. Does anyone know if this is true? The early ford store sells them complete with brakes but I dont want to spend the money if they arent going to work..
  6. Tim_with_a_T
    Tim_with_a_T
    I didn't read word for word what you have, but you're gonna want '35 - '36 spindles and bearings to go with the '36 drums you have. Then, to adapt hydraulic brakes, you either slot the holes in Ford hydraulic backing plates to fit your spindles, or you can go a little fancier and weld the holes up, weld up a retaining ring that reduces the diameter of the backing plate to match the diameter of your spindle, then you re-drill the backing plates to match the spindles. OR... you can buy repro Lincoln backing plates that have the '35 - '36 spindle bolt pattern. I think either option will work, but it all depends on what spindles you have. If you have different spindles, I would be looking to ditch the drums you have for something different.
    Hendee and Texas36 like this.
  7. Thanks for the info. Yep, I have '36 spindles. Where can I buy the backing plates for the 35-36 spindle? Early ford store sells a kit but looks like they are for 37 and up spindles. I dont mind doing the extra work to make the later bolt pattern work, but I also dont mind going the easy route either
  8. Tim_with_a_T
    Tim_with_a_T
  9. Tim_with_a_T
    Tim_with_a_T
    That ford barn post conflicts what I said about using the drums, so I would trust them as I haven't done it. I would have to have the parts in front of me to confirm.
  10. My wishbones were too wide where they mount to the torque tube so a couple cuts in each got me to where I needed to be. [​IMG][​IMG]
    I then painted and reassembled everything and got it back in the frame. [​IMG][​IMG]
    Felipe Toltecatl likes this.
  11. My dad caught me "driving my car in Wildwood" again... [​IMG]
    [​IMG] Im just happy things are taking shape now. Most likely wont make it to Bayou roundup or the moonshine run this year but possibly by the 2018 LSRU???
    glorydime, Squablow, slv63 and 10 others like this.
  12. Lookin great, keep up the nice work!!
    Texas36 likes this.
  13. ChuckleHead_Al
    ChuckleHead_Al
    Man you're rocking and rolling, great job, you're roadster is looking awesome. I need to finish my roadster.
    Sent from my SM-N920P using The H.A.M.B. mobile app
    Jeff34, '37-4D, Luke W and 6 others like this.
  14. Thanks!
  15. Thanks! Your car is sweet. There arent many '27s Ive seen that are done "right" in my eyes and yours is spot on !
    ChuckleHead_Al likes this.
  16. ChuckleHead_Al
    ChuckleHead_Al
    Thanks @Texas36 yours will blow the doors off of mine for sure, keep up the great work, I love seeing all the progress.
    Cyclone Kevin and Texas36 like this.
  17. D.Lee
    D.Lee
    Nice work and nice ideas man, I'm diggin it!
    Texas36 likes this.
  18. Thanks dude! Im just trying to keep up with you and everyone else right now.. I still need to make the trip one day to see your roadster, its pure inspiration !
  19. cmarcus
    cmarcus
    Killer work brother, keep it up! I will definitely be following along.
    Texas36 likes this.
  20. D.Lee
    D.Lee
    Thanks man!
    I hope your driving this car if you do come my way!
  21. It would be a great shakedown run and also a perfect photo opportunity! Im down
    D.Lee likes this.
  22. D.Lee
    D.Lee
    Fuckin awesome!
  23. Now onto steering.
    In order to get the F1 box to fit in the 'A' frame, I cut off the bottom tang and drilled a new mounting hole. [​IMG]
    Im moving the box a little farther back from stock location for header clearance so machining the box and using a model a flange (tardel style) isnt needed.[​IMG][​IMG][​IMG]
    Column needs to be shortened about 4 inches but will work for now. [​IMG]
    The pitman arm will also need to be bent for clearance.
    Nailhead A-V8 and ChuckleHead_Al like this.
  24. Will probably need to lean the box back a bit as the angle is too much. The wheel will hit the windshield if I shorten the column. Easy fix
  25. ChuckleHead_Al
    ChuckleHead_Al
    This was the hardest part for me, header and steering box clearance. Great job so far.
    Texas36 likes this.
  26. Thanks. Yeah Im learning that as I go. I had to unbolt the engine and raise it up a couple inches just to get the stupid thing in! Lol
  27. carbed87
    carbed87
    I like where this build is going. The trans mount is a great idea, good job on it man, this thing will be badass!
  28. Thanks dude! Ive been following your build, its looking great! I recently followed you on Instagram. I recognized your car..
  29. Went ahead and fixed my steering column angle [​IMG] now to just shorten it 3".
    So I can already tell this is the part where things will get challenging. Im using '32 ford truck pedals but the pedals are waaay too long. [​IMG][​IMG] has anyone else ran into this problem before? Will sectioning the arm mess up the geometry? Im having trouble visualizing how these pedals even worked on a stock truck as the arms are basically hitting the engine block .
    Edit: thinking about it further Im realizing that the pedal box needs to be moved further over and the arms bent a considerable amount. None the less the arms will still be too long.
    BigDTexasKid likes this.
