Projects 27 roadster build photo journal
Discussion in 'The Hokey Ass Message Board' started by bloodyjack, Jun 18, 2008.
  1. bloodyjack
    bloodyjack
    Thought I would keep all the photos as I build my 27 in one place
    Dragging her home​
    first mock up​
    are my lights to big?​
    engine mounts first bit of fabrication​
  2. bloodyjack
    bloodyjack
    needed the hogshead for my adapter​
    after a clean up​
    T5 re-built​
  3. Twisted Minis
    Twisted Minis
    Nice work so far. That transmission is spotless.
  4. bloodyjack
    bloodyjack
    It did not look like that when I got it from the pull-apart
  5. burger
    burger
    from burbs
    That's a 4WD T-5, correct? Are you planning to mate it to a torque tube?
  6. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Wow, if that tranny is indication of how clean you like things then this roadster should turn out pretty nice.
  7. bloodyjack
    bloodyjack
    Yes even the Hurst gearknob has a three speed graphic.
    I want the old look of a torque tube rearend.
  8. Crazydaddyo
    Crazydaddyo
    I like it so far. Looks like your going in the right direction
    Head lights are good. Dig the Whippet grill.
  9. mink
    mink
    from CT
    what did you do to clean that up?
  10. bloodyjack
    bloodyjack
    I cheated the transmission was rebuilt by Aamco transmissions in Everett I dont do transmissions
  11. Angry Frenchman
    Angry Frenchman
    I love A and T combo's.
  12. bloodyjack
    bloodyjack
    I made some shock mounts / headlight mounts today. followed the idea in the Tardell book modified F1 mounts with headlight cups welded on top. Also cut the spring hangers off the wishbones
  13. bloodyjack
    bloodyjack
    Little bit more done I hated the height of the F1 shock mounts (see above) so I cut them up and welded up shorter versions
    and I finaly got the nerve to zee the rear
  14. chaddilac
    chaddilac
    I like the shortened headlight mounts...
  15. bloodyjack
    bloodyjack
    Started stripping the body and fixing dents
  16. i have a feeling this it going to be a nice clean build. looks good, keep it up
    keith
  17. Irish Dan
    Irish Dan
    It's all good!....keep up the good work!
  18. Crazydaddyo
    Crazydaddyo
    Those mounts look much better lower!!!
    Keep it up.
  19. Looks like your roadster body is relatively complete....were you lucky enough to score the decklid with it?
    Would you mind if I pestered you for some pics from time to time? I'm rebuilding the back of my roadster at the mement and there's a LOT of missing pieces.
  20. bloodyjack
    bloodyjack
    Yes i got the deck lid but its a piece of shit and i have to make a new one, let me know what ya want to look at and I will post a photo
    cheers
  21. bloodyjack
    bloodyjack
    little bit more done. my A spring and mounts came. Putting them on was not so easy I had to get the torque tube off and the hubs so i could take it to a local doode to weld and I cut off the original 46 rear mounts. I did not trust my pigeon shit welds on this part. Anyways here are some pictures. Its a posie smaller than normal A spring that sits 3.5 inches lower but my AV8 book tells me to pack it without the last 3 springs not sure i dont want to cut them as spacers so might have to get something to use as a spacer. What do you guys think?
  22. Crazydaddyo
    Crazydaddyo
    My understanding is that the long springs are for ride and the short ones are for ride height. If the last three are left out it should ride the same, it will just be a little lower. It is easier to put the short ones back in.
    Will we see this on the road before winter?
  23. bloodyjack
    bloodyjack
    That depends on a couple of things
    1. Just lost my job so I have time to spend on build but no money gotta find a job!
    2. You!
    Hows the torquetube interface going?
    Actualy CD I have a couple of questions, I had to cut the drive shaft connector off after grinding and beating out the rivets and i think I am going to have a driveshaft made with 2" tubing therfore I can use any end I like for the torque tube knuckle and was thinking maybe I can use an off the shelf joint instead of you making a custom one. What do you think?
    I am actualy aiming for Hotrodarama next year
  24. CRH
    CRH
    from Utah
    BloodyJack is a jerk!!!
    Why??
    Because he is doing a way better job on his '27 roadster than I am on mine!
    Crap!!
    (By the way, nice setup...!)
  25. Crazydaddyo
    Crazydaddyo
    PM me some pictures of what you have so that I have a better idea of your TT set up.
  26. bloodyjack
    bloodyjack
    What motor you running in your 27?
    I am useing a 53 mercury V8
  27. striper
    striper
    I had the same dilemma. I made a spacer.
    1. I can always put the leaves back in if I want to.
    2. Why cut up good Model A parts to make spacers out of?
    Build is looking good so far.
    Pete
  28. looks great man.. going to have alot of character.
    good luck..
  29. CRH
    CRH
    from Utah
    Dude, your motor is going to be perfect. I hate to admit it, but mine is a Ford 302 and the trans is a C-4. I did a little customizing on some Speedway cheapo valve covers, welding on little tubes that guide the plug wires . It's kind of a wannabe early-Olds -like look. And I got a little carried away with the alternator fan "color." 1978 called and wants it's "custom styling" back...
