Projects 27 ford
Discussion in 'The Hokey Ass Message Board' started by orangecoupe, Jan 9, 2011.
  1. orangecoupe
    orangecoupe
    from florida
    this my 27 ford it is sitting on 31/48 rails, with 39 wide five brakes on a 35 axle in front 40 in the rear. just got all the mock up done starting on finish work now just finished filling and boxing the frame. just wanted to see what everyone thought.
    just added some new pics at bottom
  2. propwash
    propwash
    from Las Vegas
    lookin' good so far - I would recommend that you get that radiator cover lowered so that it is not higher than the top of the cowl...section it, chop it, whatever - when they stick up so high, the ruin the appearance of the car.
    I don't know what 31/48 rails are, as they are not inclusive through those years. Nonetheless, your project appears to be coming along just fine.
    dj
  3. fab32
    fab32
    Shaping up nicely. I was also thrown off by the '31/'48 rails. could you explain?
    Frank
  4. truckncoupe
    truckncoupe
    Yep, looking good!!!:D
  5. orangecoupe
    orangecoupe
    from florida
    to elaborate on the rails the front and rear frame sections are 31 A, and the mid section is a 48 truck which is taller and it has a natural kick up that flows into the A rails in front.
  6. Mindover
    Mindover
    from England
    I like it and the fact thet you have used what you have to make a body and chassis from not much. Whats the motor? I agree with the other guys about the rad shell.
    I am just starting my '27 on '32 rails... I will be making most if not all of the body for that though.
    Keep posting your progress I would like to see what it turns out like.
    David
  7. orangecoupe
    orangecoupe
    from florida
    here are some pics of frame
  8. J scow
    J scow
    from Seattle
    x3 on the grill shell. Other than that it looks great! The frame looks stout I like it!
  9. MATACONCEPTS
    MATACONCEPTS
    i'd chop the grille & the frame & raise the axle(lower the car)
  10. That's a great ride! Can't wait to see it road ready!
    I just read a thread on here about brush painted cars. Very cool and they look the part! You thought about brush painting that thing?
    Always wanted to brush one - probably on the next car we build....
  11. orangecoupe
    orangecoupe
    from florida
    well here are some new pics of frame and suspension.
  12. orangecoupe
    orangecoupe
    from florida
    here are some new pieces i have been working on first i took a 390 t bird valve cover and grafted it in my 200 valve cover, also my dash that i re-arched the lower portion and integrated this cool speedo i found, also my 39 wheel and front spindles and bacing plates
  13. freebird101
    freebird101
    that looks great
  14. crider
    crider
    I like it! looking good so far
  15. 42 chevy
    42 chevy
    I like it, but agree about lowering the grille shell.
  16. orangecoupe
    orangecoupe
    from florida
    working on finding shorter rad with correct hose placement not having much luck. painted rear axle pieces today
  17. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Looking good. Keep the updates comin'.
  18. orangecoupe
    orangecoupe
    from florida
    well got the rear painted and built and installed. working on the body now hope to have in primer in 2 weeks. also working on rebuilding motor and trans.
  19. Nice work ,I like it......
  20. Looking good!
    Speedo is from a Mini.
  21. Atwater Mike
    Atwater Mike
    You know, that '37-'41 axle is the worst choice ordinarily, because of its close spacing between wishbone bolt & king pin...but I said 'ordinarily'.
    You have set this up with spring behind, long 'bones, and clean-clean-clean!
    I love to see parts like this massaged into interesting versions of the home-built art of 'Roadstering'. This is a treat.
  22. orangecoupe
    orangecoupe
    from florida
    got the brakes done shes a roller tranny done, workin on motor need an oil pan if anybody out there has one..
  23. I like what I see - maybe lower the grill shell some - looks good
  24. Very nice! Keep us updated!
    As has been stated lower that rad shell!
  25. 3wLarry
    3wLarry
    from Owasso, Ok
    You don't need to lower the '30 Model A grille shell...you need to sell it and get a '28-'29 Model A grille shell...they're shorter, fit perfectly, and will look great...trust me.
    kidcampbell71 likes this.
  26. I like it, plus I have a soft spot for wide fives. Keep us updated!
  27. Johnny-B-Bad
    Johnny-B-Bad
  28. captainjunk#2
    captainjunk#2
    i like it , you did a really nice job on the chassis / frame , very cool little car
  29. smarg
    smarg
    I'm looking forward to see how this one turns out!
    The frame looks SWEET!
  30. Ed Zackley
    Ed Zackley
    from Hokeyhomey
    That's gonna be nice!
