Hot Rods 26/27 T roadster cowl doors etc. differences etc. discussion or questions.
Discussion in 'The Hokey Ass Message Board' started by porknbeaner, Jun 11, 2020.
  1. The37Kid
    The37Kid
    WOW! Great looking stuff. Is this all billet in a CNC machine, press the button and out comes a hub? I keep buying Lottery tickets, will call the day I win. :):):):) Bob
  2. Kevin Pharis
    Kevin Pharis
    My hubs and caps are billet cut chromoly steel/manganese bronze, and the wheel centers are cast chromoly steel with all critical surfaces machined then ground and polished on the outer surfaces.
    Raw;
    Machined and polished;
    Internal machining;
    Tman, HotRodWorks and alchemy like this.
  3. The37Kid
    The37Kid
    It just amazes me to think of all the machinery and fixtures it must take to make that first wheel, then perfecting it to mass produce others. Thank you for taking the time, I'm sure there is a huge investment of time and money, I will be a customer some day. Bob
  4. rusty valley
    rusty valley
    it is a work of art, i have seen Kevins work before. now back to model T's, here's a photo of my bent up 27 that thanks to @Kevin Pharis can be identified by the one piece floor, attached to the quarters, with the front wall sloping up about 6" at the seat back. i originally thought the hump for the cross member had been squished down, but after Kevins description i see that it was flat, and in this case got pushed up from some form of abuse by the rear cross member. note two spit rivets that must have held some anti squeak fabric of some sort. IMG_0777.JPG
    The37Kid likes this.
  5. Kevin Pharis
    Kevin Pharis
    Your trunk floor is bout the same shape as the one that was in my ‘ol roadster. Barely holding shape, and not good enough to straighten out. I was able to gain access to a Pullmax, and made up a new trunk floor that was just about an exact copy of the original. Have pics somewhere...
    rusty valley likes this.
  6. Gofannon
    Gofannon
    Is this a roadster or roadster pickup? It has a trunk floor, but smooth seat back and no attachment points for turtle deck.
  7. Gofannon
    Gofannon
    Different styles of key hole in the deck lid. Not sure where I saved the bottom pic, perhaps it's an early T??
  8. Kevin Pharis
    Kevin Pharis
    That is certainly the ‘26 trunk floor... but interesting that there are no holes for the trunk...? Seem to remember 2 bolt holes in each vertical and 2 just below the tack strip on my ‘27
    HotRodWorks likes this.
  9. The37Kid
    The37Kid
    [​IMG]Rusty, What does that piece in the battery access hole attach to. I can understand why there is no rear crossmember bump, the floor sits on the rear platform that is about three inches tall. Great to see both style floors. Bob
  10. Kevin Pharis
    Kevin Pharis
    If there are no pics... it didn’t happen... right?
    I didn’t like the new trunk lid and below trunk lid panel. They just weren’t the right shape (no compound curve). I made the below trunk lid panel that fit right, but never got around to taking the trunk lid apart to put the right curve in it.
    This car also was not equipped with a top, and still had the Bakelite plugs in the top iron holes
    94BF554B-544E-4580-BEC4-74B330DE0241.jpeg DF6C0401-C1C8-4CD1-BD79-8BA204532331.jpeg E359F0FE-C25F-4A79-9C9C-8A2A1EA6D608.jpeg 9BF522A6-F196-44F5-B626-7B8D7E531524.jpeg
    Tman, The37Kid and Gofannon like this.
  11. The37Kid
    The37Kid
    I'm saying Roadster, no need for the extra metal on a from the factory Pick Up.
    Bob
  12. Kevin Pharis
    Kevin Pharis
    Here’s a shot from down unda showing the embossed square sitting right on top of the cross member
  13. The37Kid
    The37Kid
    Just remembered there is an early and late dash, so maybe the under steering column bracket is slightly different too.
  14. What a great Tread!! (thanks Beano). After reading it twice i can say i can't ad anything new as it' been covered. I have been out and looked mine over and as i bought it as a 26 (hence my handle) it didn't take long to know it's all 27. Back when these were new, for $25 the dealer could sell you a pick up box to change you roadster into a pick up. Mine was a roadster as there is light pitting where the trunk was bolted to the main body. JW
  15. Osoty
    Osoty
    What are the differences between the early and late dash?
  16. The37Kid
    The37Kid
    It was back in the 1970's that I had an early and late one, I think the sweep on the bottom differed. Bob
  17. Ken Smith
    Ken Smith
    Alliance Vendor
    I’ve had (2) 27 roadsters and they both had 2 nuts/bolt holes along each vertical. I’ve never seen one without them. Maybe they didn’t have them early on and later found they needed additional attachment points for the trunk.
  18. GuyW
    GuyW
    Thanx for the info. According to the old R&C article these were Buffalos. The article also has some better photos.
    Jiggler Joe Gemsa's T article pg 1.jpg Jiggler Joe Gemsa's T photo 1.jpg Jiggler Joe Gemsa's T photo 2.jpg
  19. Kevin Pharis
    Kevin Pharis
    That pic is a lot more clear! Definitely Buffalo, size #4 or possibly #4.5, with 18” lock ring rims. #4 Buffalo wheels are like hens teeth, and #4.5 are almost non existent. There were also several variations of wheel centers in these sizes... could be B, CB, HC, or MS series wheels.
    I helped a guy put together a set of #4 Buffalo hubs years ago. He had scrounged up 4 hubs, and had an original set of wheels... but the hubs wouldn’t interchange into the wheels! I systematically trimmed and resized a couple of the hubs so they would all interchange
    GuyW likes this.
  20. Kevin, you need to just start an entire thread on these amazing wheels just like your carbs!!!
  21. The37Kid
    The37Kid
    I'm sure that is an in house machining secret, but it would be fun to watch. Bob
  22. Osoty
    Osoty
    Per this thread, I have a 26 and a 27. Both have a raised area on the seat back and are not flat like that other pic. And I did find a couple of differences in the dash panels between the years. Like was pointed out about that bump where the top of door meets the cowel, one is also bumped out. Also, the stamping for the choke is different
  23. Osoty
    Osoty
    Here's the difference on the choke bits, and the flat corner on passenger side
  24. The37Kid
    The37Kid
    THANKS! You have to admit that is a good memory on my part, it was 50 years ago I had one of each. :cool::cool::cool::cool:Bob
  25. rusty valley
    rusty valley
    osoty's bottom dash pic looks like my 27 bent up roadster. have a 26 touring in the barn, will check on that later
  26. Osoty
    Osoty
    Yeah, I think the difference in thswoop on the bottom may be between a roadster and a closed car. You did intrigue me Bob and made me go take a gander. Hope all is well over there. Thanks, ty
  27. The37Kid
    The37Kid
    I find these threads to be a lot of fun, and educational. This is a NOS Stewart Speedometer that would fit in the hole of the dash you posted. I've had it for over 40 years a gift from Doc Mead, hope to have a '27 to put it in some day. Bob DSCF0827.JPG DSCF0828.JPG
  28. Osoty
    Osoty
    It may take a bit but take your pick Bob and its its yours
  29. Kume
    Kume
    i have gone with Riley wheels
  30. The37Kid
    The37Kid
    Looks like a Bugatti lost its headlights as well, nice looking car! Bob
    Greg Stokes likes this.
