I'm trying to put a smaller pulley on my 250. Running into problems trying to get the belt grooves to align. I have a 1967 and a 1976 engine, and while the water pumps appear to be the same, the snout on the 67 is about 1/4" shorter. I thought all the 250's had the same pumps. Am I wrong? Any ideas on what pulley I need? I really don't want to change out the balancer if I don't have to, I also don't want to resort to an electric fan. Thanks for any ideas.
The mounting is the same but my old W/P catalog shows several different part numbers used. If the pump for the 76 engine allows the pulleys to line up simple go get a new 76 pump !! They are not expensive.
Thanks John, But actually seems like the older, shorter pump will line up better. I was just wondering if the 1967 style pump will work on the newer engine.
yes most 194-230-250 blocks where the same... the 292 was damn near different from the deck height to the engine mounts...but some parts still interchange now i see your problem is you have an earlier block now the inline 6 194-230-250 had two difference models the ones produced in 1962-1972 and 1973-1985 so several little changes were done....but one large change done with the integrated head... you would need to find an earlier 1962-72 i6 pully to work right.
