Technical 241 hemi oil capacity
Discussion in 'Traditional Hot Rods' started by sstock...not, Jun 20, 2018.
  1. sstock...not
    sstock...not
    from boston
    Good evening. Acquired a new project....1927 Ford roadster on a 28 frame with a 241 red ram hemi. Leaks a little bit of oil so I want to start with changing the oil. There are no marks on the dipstick so I was hoping someone can tell me what the oil capacity is on these engines. Thanks in advance.
    Butch
  2. Hombre
    Hombre
    5 Qts with the filter.
  3. 32 Spitfire
    32 Spitfire
    I use 5 quarts of Valvaline Racing 50 weight oil (not synthetic) in my 32 Coupe below and always one little bottle of zinc additive . For starting its always in a heated building. You could go with Valvaline 20-50 Racing oil and one zinc additive if your car is not in a heated environment. The Valvaline Racing oil is a high zinc blend.
    https://www.jalopyjournal.com/forum/threads/1932-ford-old-school-coupe.1076302/
    High Noon
    sstock...not and LOU WELLS like this.
  4. sstock...not
    sstock...not
    from boston
    Thank you for the info.
