Hot Rods 2357 40CP will standard 32CP flasher work ?
Discussion in 'The Hokey Ass Message Board' started by Rustytoolss, Aug 2, 2017.
  1. Rustytoolss
    Rustytoolss
    If switching from 1157 bulbs (32CP) to 2357 bulbs (40CP). Will the standard 552/536 flasher work since it is rated for 32CP ?
  2. The watt rating almost the same, so the flasher should work. The turns will likely flash a bit faster. Be aware that rated lamp life on the 2357 brake/turn filament is only 1/3 of the 1157, so you may be replacing lamps more often....
  3. onetrickpony
    onetrickpony
    from Texas
    Yep, what Crazy Steve said. The more wattage, the faster the flash but it should be OK.
  4. 302GMC
    302GMC
    from Idaho
    Plastic taillight lenses ? Don't stand still with your foot on the pedal for too long ...
