235 straight 6 running hot....DRIVING ME NUTS!!
Discussion in 'The Hokey Ass Message Board' started by PossumJR., Sep 29, 2012.
  1. fnla39
    fnla39
    Is the anti-freeze rusty, could engine need flushed? If it isn't coming out of radiator are you having to add any periodically? Could mean it's being puuled into cylinder during inake stroke.
    One way to check for a bad head gasket is to fill radiator up to neck, start motor and watch for bubbles getting increasingly larger and more frequently. Engine should be cold of course.
    Is there any reason your not running a stock housing? I can't lay off the thermostat need because it caused me to go through everything before I checked the most common. Even after a greybeard told me to change it.
  2. henryj1951
    henryj1951
    from USA
  3. belair
    belair
    I had a similar problem on my 235 55 chevy. The radiator was crudded up inside. Chased my tail on that for a couple of days.
  4. henryj1951
    henryj1951
    from USA
  5. amxroscoe
    amxroscoe
    My 31 had a thermostat I put in on the top rad hose,worked great,staged the coolant long enough to keep the solid lifter 289 cool...two solid pipe flanges,2 nutz and boltz,washer,gaskets(2)...done like dinner.
  6. henryj1951
    henryj1951
    from USA
    in 1970 i built a water pump system for
    the current drag car...
    it was a one only configuration that would only
    pump the fluids when i flipped the on switch.
    and it was set up for some of the fastest 5 gallon water exchanges
    in the pits.
    POSSUM JR where Are you we want to help here...
    he needs to tell us all about the modified (lack of) thermostat housing....
    so HOLD THE PHONE TILL HE gets back in here
  7. RWENUTS
    RWENUTS
    from Nanaimo BC
    Water pumps cavitating. Change out that bottom hose. Or put a coil in that one.
  8. boooooob
    boooooob
    POSSUM JR
    Have you tried to take the upper radiator hose off the radiator, get a water hose, seal it inside the upper radiator hose turn it on full , see if you get good flow out of the upper radiator hose connector(since you don't have a thermo)....
    boooooob:)
