235 Chevy Truck motor starter question
Discussion in 'The Hokey Ass Message Board' started by Sir X Loin, Sep 30, 2013.
  1. Sir X Loin
    Sir X Loin
    Can someone tell me if I can use a starter that isn't foot operated for this set up? I am doing a T5 swap in my 51 sedan and just came across a truck bellhousing. Thanks.
  2. Sir X Loin
    Sir X Loin
    Doh!! The motor and belhousing are from a 55 3100.
  3. turnbull001
    turnbull001
    I don't see why not, it is just a momentary switch. Should just be able to change the ignition switch to one with the starter switch in it and rewire it. This is just a guess based on a thought process, though. I have never tried to do this swap myself.
  4. Sir X Loin
    Sir X Loin
    That's what I was thinking. Im just tight on money and want to make sure everything will mount and mesh correctly.
  5. 5559
    5559
    from tn
    I changed a 58 with a 235 to a later style starter----best i remember all i had to do was change the ignition switch to one with a start position , replace the truck starter with one for a 55-57 6cyl car &run a 10 ga wire from the sol termnial on the switch to the solinoid
  6. squirrel
    yup, just make sure the flywheel and starter match. 6v engines used a 6v starter, 12v engines used the 12v starter. The gear teeth are different.
    Trucks had foot switch (thru 59, with manual trans), cars had key switch.
  7. 1964countrysedan
    1964countrysedan
    from Texas
    I am glad to see "squirrel" back here in action.
  8. 6inarow
    6inarow
    I was thinking the same thing.
