Read complete description! This is a '58-'62 - 235 engine #3769716 with the preferred head #3886848. Both virgin. Have new .060 pistons/ring - block will need bored. Have new rod/crank bearings .010 - Crank will need turned. Includes the following parts; cam bearings, orig. & nos water pump, nos oil pump, orig. & nos rocker arms/shaft, solid & hyd lifters, 2 cam shafts, new intake & exhaust valves, new valve springs, new crank/timing gears, 4 carbs (need rebuilt) 2 distributors + 1 electronic distributor, extra side cover & valve cover, 1 1/2 gasket set, Nice flywheel, Plus Fenton headers and Thickstun intake. Everything in photos. $1550 for all or $1,000 without Fenton/Thickstun/carbs. A great motor for your vintage hot rod, or vintage restoration . Call Eric 816-564-8815
