235 Chevy Engine - Need help!
Discussion in 'The Hokey Ass Message Board' started by moerdock, Aug 13, 2009.
  1. moerdock
    moerdock
    Hi,
    have a 235 Chevy 6inline engine in my 50s Chevy Coupe...
    But i need more information about the engine...
    Here the number
    0386362 F54X
    Must be an engine from 1954...
    Could anyone give me more information?
    THANKS!!!
  2. Truckedup
    Truckedup
    F54X,F for Flint Michigan,54 for 1954 as you said.And my info has no listing for an X in 1954.But an X in 56 was for 235 engines in light duty trucks.Supposedly truck engines have an aluminum cam gear instead of the fiber one found on car engines.And a truck engine should have solid lifters like some or all manual tranny car engines.There are exceptions to this stuff and over the years things do get changed.
  3. Kopperhead
    Kopperhead
    Check the engine and head casting number and we can give you more information.
    If I understand the F54X right, the engine is a 235 with casting no 3701481? If so its out of a 54' car with manual trans.
    Cylinder head no 3835913?
    I hope this information helps you identify you engine.
  4. rockogrease
    rockogrease
    from So. Cal
    what info are you looking for?
    i know its a truck motor
  5. moerdock
    moerdock
    Yes, the number on the head i found is:
    3835913
    So it is an 235, from 1954, truck engine, right?
    THANKS!
  6. Snarl
    Snarl
    Per Hollander, F54X is a 1954 235 from a 1/2 ton truck with a standard clutch.
  7. moerdock
    moerdock
