235 Chevy carburetor upgrade...
Discussion in 'The Hokey Ass Message Board' started by Fat Hack, Apr 12, 2009.
  1. Fat Hack
    Fat Hack
    from Detroit
    That grenade is my "Emergency Roadside Rebuild Kit"!!! Every Stovebolt driver needs one, ya know?! ;):D
  2. Fat Hack
    Fat Hack
    from Detroit
    This swap is really a no-brainer! Aside from making that simple linkage adapter, it was a bolt-on deal. The pedal feel and travel are the same as they were with the stock carb, and the engine runs MUCH better. These Economaster carburetors were designed and calibrated by Holley for 1977-78 Chevy 250 engines, so they work out real well on a 235, too. They're tuned with economy in mind (I even left the idel mixture limiter cap on mine), which is cool by me! The car actually IDLES now, which puts it miles ahead of the stock carb it replaced!
  3. Duration
    Duration
    from Wayne, MI
    what is the holly part number for that economaster carb?
  4. mikebte
    mikebte
    from Arizona
    Anyone looking to do this swap needing info. I have a 82 ford fairmont with a 200 I6 and it has the same carb. It is a holley 1946. Same Exact carb. Was unable to find that carb used on a 250. So there you go. Holley 1946 used on Ford 200 I6. Have fun.
  5. chigger
    chigger
    where can the adapter that
    LEADED is talking about be found?,,, any ideas?
  6. mikebte
    mikebte
    from Arizona
  7. 1946Chrysler
    1946Chrysler
    from Boerne, TX
    Very cool, man. Another idea for someone who is planning on keeping their 235 as-is would be the dual-carb setup you see on here all the time. I couldn't help but mention it because it looks so freakin' cool!
  8. KARPARTZ
    KARPARTZ
    from ST LOUIS
    I have a 57 Chevy 235 I woulds like to put this Holly Economaster iv carb on. Can you supply the Holly prt number? I would like to order one for my 53 Chvey truck its going on.
  9. worthop
    worthop
    yeah, what KARPARTZ said.....
  10. duece-32
    duece-32
    from Alberta
    Hi there, love the article on the carb swap to a Holley Economaster. I'm in the same boat with a 230 in my old Poncho. I asked my local parts store to order one for me, I was asked if I could find a casting number on the carb. Would you be able to check your carb and let me know? I would absolutely love to get that leaky, fat running old rotten chester off and replace it with something from this century! Thanks in advance.
  11. Fat Hack
    Fat Hack
    from Detroit
  12. bowtie56jw
    bowtie56jw
    realizing this is a couple year old thread..........any updates? has anyone else tried this or some other carb? im desperate here.
  13. El Caballo
    El Caballo
    The Economaster I have is for a Ford 200-250 and it performs quite nicely on my 235. The linkage had to be modified, but so what?
  14. bowtie56jw
    bowtie56jw
    can you post a pic or pm me one so i can see what you mean.
    thanks
  15. chiro
    chiro
    Don't pm him. Post it here. I'm interested as well
  16. Cosmo49
    Cosmo49
    Hope the op sold the 235 to someone who really wants it and can use it. I have 86K miles on a '56 235, '49 Chevy 1/2 ton dd/only vehicle now with two X 2 bbl carter-webers.
  17. bowtie56jw
    bowtie56jw
    back up to see if anyone has used any other carb on a 235
  18. smoked1
    smoked1
    Ive got two 235's Ive had for twenty years with stock carbs that have given me zero problems, and 19mpg with stock gearing in 41 and 59. Car and truck. It looks like a good swap tho if you have a shitty carb.
  19. xderelict
    xderelict
    Stromberg BXOV 2. I like them much better than the Rochester Bs.
  20. bowtie56jw
    bowtie56jw
    cosmo that set up looks cool but i want to stick with a single carb.
  21. Hsquared
    Hsquared
    finally, some pictures I can actually use now. thanks FatHack
  22. junkyardjeff
    junkyardjeff
    I remember reading this back then and will have to look for one of those carbs,I never cared much for the original carb on my 57 235.
  23. bowtie56jw
    bowtie56jw
    i have a good running b on her now after going through 3 bad ones. i still would like to find one like the op found and used.
  24. Excellent write up, been jacking with the 1BBL in a '57BA for months to get it to run smooth. I'll give it a shot and thanks for posting pics of your bracket.
