Technical 235 bellhousing
Discussion in 'Traditional Hot Rods' started by ned5049, May 16, 2019.
  1. ned5049
    ned5049
    What bellhousing would mount a 4 speed saginaw to a 57 235 6 cylinder Chevy? Any help would be appreciated Thank you
  2. 302GMC
    302GMC
    from Idaho
    The one that came on the engine if it was a 3 speed. Any '55 up will work, but you need the one that aligns with the mounts on whatever it is you're putting the engine & trans into.
    6inarow and Hnstray like this.
  3. KenC
    KenC
    Also, 49-54 pickups have the same bolt pattern as 55 up. Nice if your working with a pickup chassis, mounts work and changes to open driveline.
    Back in the day the pickup trans case was used to mount SBC 8s in a car chassis retaining the torque tube. New mounts of course, but not driveline changes.
    anthony myrick and 302GMC like this.
  4. my 49 truck 235 has an early 60s sagnaw car 3 speed bolted up to it
  5. ned5049
    ned5049
    Thank you all. That simplifies everything.
