Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Dick Stevens
    Dick Stevens
    Just get the regulator rebuilt, it's much cheaper than replacing it. That will leave more to spend on the hot rods!
    Stogy, loudbang and Paul like this.
  2. Paul
    Paul
    Editor
    Yes but, the hoses and torches are getting worn out too.
    I dream of a nice new complete set.
    In the meen time I think I do have a rebuilt regulator somewhere...
    Stogy, brEad and loudbang like this.
  3. Paul
    Paul
    Editor
    Made a little progress over the weekend.
    Started the turn ins toward mufflers..
    And played with possible collector block off caps..
    PXL_20211002_225555306.jpg PXL_20211002_225645129.jpg PXL_20211002_231752712.jpg
    Sancho, cactus1, Stogy and 14 others like this.
  4. Paul
    Paul
    Editor
    welded some glass packs in and ran short straight tail pipes under the rear axle,
    not enough room to run them up and over.
    two hangers on each pipe.
    tail pipes exit at a similar angle as the collectors.
    OFT, bchctybob, Sancho and 8 others like this.
  5. Paul
    Paul
    Editor
    block offs for collectors made of 1/2" aluminum plate,
    cut with hole saw on drill press.
    made some wing nuts similar to Cal Custom valve cover wing nuts
    but steel and with 7/16 bolts,
    polished.
    welded flat bar to coupling nuts,
    drilled the collector tube for plug welding tube to flat bar
    and welded, filed, sanded and bolted them together.
    to get a close to tight fit I rubbed the tube end with a sharpie
    turned the plate in the tube by hand to locate high spots,
    filed the tube where ink rubbed off
    Repeat until when the plate was in place and turned it wiped the ink all the way around.
    PXL_20211007_222509647.jpg PXL_20211007_223945894.jpg PXL_20211008_162321991~2.jpg PXL_20211008_222002429.jpg PXL_20211008_222838763.jpg PXL_20211008_215402410.jpg PXL_20211008_225512641.jpg PXL_20211008_225724954.jpg
    GuyW, Atwater Mike, 39custom and 22 others like this.
  6. 64 DODGE 440
    64 DODGE 440
    from so cal
    Short and simple. Looks good to me. Love the sound of an Olds through glasspacs.
    loudbang, Stogy and Paul like this.
  7. The 39 guy
    The 39 guy
    The header plugs came out great! You ideas and craftsmanship keep me anticipating each of your posts as ther eis always something to learn. Thanks for sharing!
    OFT, loudbang, Stogy and 1 other person like this.
  8. Paul
    Paul
    Editor
    Couple pix of plates,
    used a 3" hole saw to cut a groove for the 3" tube to fit in,
    Drill again with 3-1/4" hole saw
    turning the groove into a stepped edge.
    PXL_20211003_235924318.jpg PXL_20211004_005144974.jpg PXL_20211008_023828333.jpg
    jebbesen, winr, Just Gary and 19 others like this.
  9. gonzo
    gonzo
  10. Paul
    Paul
    Editor
    Thanks all,
    I'm curious to see how well the bolt system holds up.
    It's a pretty harsh environment in there.
    Hoping with periodic reapplication of anti seize to the threads it won't become an issue.
    bchctybob, Sancho, Stogy and 2 others like this.
  11. High test 63
    High test 63
    Paul,
    I sure admire your skills and vision.
    Your T and the craftsmanship it displays are an inspiration and education to me.
    Thanks for taking the time to share it with us .
    cactus1, Paul, Stogy and 1 other person like this.
  12. Paul
    Paul
    Editor
    Thanks man.
    Stogy and loudbang like this.
  13. Stogy
    Stogy
    Upping the 'like' again...Fabrication extraordinaire @Paul
    OFT, loudbang, jebbesen and 1 other person like this.
  14. I was wrestling with an ugly tail shaft leak on the project this week. found myself saying " crap, what would Paul do with this!" Had a vision, no more leaks now. Love this build thread. Keep it up Paul, great job, as always.
    bchctybob, brEad, loudbang and 4 others like this.
  15. Paul
    Paul
    Editor
    Ha! Now that's funny!
    loudbang and Stogy like this.
  16. 31Apickup
    31Apickup
    This is the one build that deserves everything to be chromed!
  17. RodStRace
    RodStRace
    you are going to need space inside for a welder's glove or oven mitt and a place to stick those when they are hot!
    Atwater Mike, Tim, Stogy and 3 others like this.
  18. coming along nice Paul ! nice work
  19. Paul
    Paul
    Editor
    That would be nice, maybe after I win the lottery..
    Oven mitts and a tea cozy?
    Thanks Rob!
  20. bchctybob
    bchctybob
    I did the same type of plugs for my '27T with similar bolts holding them in. I did mine on my lathe but I really like that you did yours using hole saws. Now that's creative.
    You're right about the harsh environment. It didn't take long for the bolts on mine to seize so I had to break them off to remove them. That's with anti-seize. I had uncapped them once or twice for a cruise and reapplied the anti-seize too. I ended up going to a six bolt round flange and having the headers chromed. I hope you have better luck.
    The whole system looks great! Looking forward to the running video.
    jebbesen, OFT, Paul and 2 others like this.
  21. shorrock
    shorrock
    just leave a threaded bolt in the tube and use a winged nut for holding the cap on
    Atwater Mike, Tim, Paul and 2 others like this.
  22. Paul
    Paul
    Editor
    Thanks guys,
    I really don't want a bolted flange here,
    and I don't want a bolt sticking out when the caps are off.
    Maybe something other than plain automotive anti-seize.. something specific to this type of environment.
    I know just the person to ask.
    bchctybob, Stogy, OFT and 1 other person like this.
  23. jebbesen
    jebbesen
    from Winona, MN
    The copper anti seize seems to work a lot better than the alum based stuff in my experience. Also if you make the bolts just long enough to just fully engage the threads that probably helps so there aren't any exposed threads inboard of the nut to corrode. My old neighbor swears by white lead for flathead or knuckle harley exhaust spigots. I came across an old can of Dutch Boy white lead and he was thrilled! Just don't bring any finger foods to the garage when the can is open. Lol
    bchctybob, The 39 guy, Stogy and 2 others like this.
  24. Paul
    Paul
    Editor
    Firewall
    3/16 aluminum plate
    Paper pattern
    Rough cut
    Sand with DA, 180, 220, 500, 1000 grit
    red Wenol polish
    Install with 3/16 stainless carriage bolts
    PXL_20211016_235950739.jpg PXL_20211017_230153620.jpg PXL_20211019_014421543.jpg
  25. jebbesen
    jebbesen
    from Winona, MN
    Looks great! Plus you'll be able to clearly see any oil leaks at the back of the valley should they ever happen! ;-)
    loudbang, Paul and Stogy like this.
  26. Paul
    Paul
    Editor
    Yes, one more thing to keep clean.. :rolleyes:
    Stogy, loudbang and jebbesen like this.
  27. Tim
    Tim
    from KCMO
    Looking good!
  28. Paul
    Paul
    Editor
    Reassembly continues...
    PXL_20211021_001214700.NIGHT~2.jpg PXL_20211021_001543536.NIGHT~2.jpg PXL_20211021_182748798.jpg
    Just Gary, patmanta, brEad and 10 others like this.
  29. Tim
    Tim
    from KCMO
    Man that’s far out
    Stogy, Paul and loudbang like this.
  30. Paul
    Paul
    Editor
    super short clip with sound of glass packs.
    best played through speakers
    winr, patmanta, bchctybob and 10 others like this.
