Customs 225 slant six in shoebox ford?
Discussion in 'The Hokey Ass Message Board' started by The N00B, Jan 15, 2018.
  1. The N00B
    The N00B
    Hi everyone,
    I am a bit of a self confessed N00B (I am considering my first car project for this spring - Shoebox Ford minus the power train), so just seeking some advice.
    How easy/difficult would it be to put a 225 Slant six in a 1949 Ford?
    Asking as I already have a rebuilt 225 with auto (push-button) trans - and I want to try to save some money by using what I already have kicking around the garage.
    thanks in advance
  2. The N00B
    The N00B
    I should also maybe ask if adapter plates are available to mate a 225 to the original Ford transmission (probably not) and if this is a totally ridiculous idea - what might an affordable and easy to install option be (Ford 300 inline 6?)
    thanks again!!
  3. khead47
    khead47
    sell the /6 and get a 223 ford.
    The N00B and lawman like this.
  4. belair
    belair
    That does not sound like a good plan for a someone new to the hobby. That said, Welcome. Use the search. There's a thread about the 300 in a shoebox that's about 3 weeks old. Do an intro, read the rules, and have fun.
  5. Mike51Merc
    Mike51Merc
    Ford 6, Ford 8, Small Block Chevy---- anything but a slant 6!
    Mr48chev and The N00B like this.
  6. ClarkH
    ClarkH
    Good reasons to stick an oddball offbrand engine in a nice car:
    It will produce a lot of power.
    It's a cool engine.
    It's a powerplant your grandfather originally ran at Bonneville.
    Bad reasons to stick an oddball offbrand engine in a car:
    You already have it.
    I've had a few slant-six powered cars in my day, including one I drove through Mexico for a couple months. The first (and only) word that pops into mind is "reliable." I guess that's OK to a point, but this is a hot rod site. I believe there were some hi-performace accessories made in the day for the slant six that could increase your power and coolness, but they're hard to find. And once you pay for them, your "savings" of using the slant six over a nice Ford 6 or 8 will evaporate.
    The N00B and 49ratfink like this.
  7. Mike51Merc
    Mike51Merc
    A buddy of mine drag raced Chrysler slant sixes "back in the day". They're good reliable engines that can put out some ponies.
    Still, no reason to swap one into a shoebox Ford.
  8. 49ratfink
    49ratfink
    that would only be a good idea if you wanted your car to be worth more with no motor than a running car.
  9. Los_Control
    Los_Control
    from TX
    The slant 6 is a cool motor, nuff said!
    Hnstray, Blues4U and The N00B like this.
  10. RichFox
    RichFox
    Slant sixes are cool in the right place. In your Ford, you would be going down in cubic inches. Except to make class, that is almost never the idea when building a hot rod. I would think you should look for a V8 in the 400 inch range.
    Gr8laker and ClarkH like this.
  11. Atwater Mike
    Atwater Mike
    Remembering ol' Tex Smith... "XR-6" That was an exception, of course.
    Blatant example of the legend of one of our friends on here...
    "Don't make a wood wrench just because you have the material on hand"
    Hnstray and Mike Miller like this.
  12. southerncad
    southerncad
    All I gotta' say is why build another belly-button Shoebox...go for the slant-6....if that's what you like...do it.
    robracer1 and The N00B like this.
  13. southcross2631
    southcross2631
    Sounds like a good idea. A better idea would be to install 2 of them and make it a V-12. It would be twice as weird then. Sell the slant 6 to a Mopar guy and put a Ford in it.
  14. BJR
    BJR
    First measure the length. Most cars have the recess in the firewall in the center. The slant 6 needs it on the right side for head clearance. Right where the heater is on most cars. I bet it will not fit without major surgery to the firewall, and relocating the heater.
    The N00B likes this.
  15. Mr48chev
    Having worked on a lot of Slant sixes back in the 70's they are a royal ass pain to work on in a Mopar let alone in anything they don't belong in. If you were building a little low buck T bucket we would say head on. In a Ford Shoebox you kill the value of the shoebox if it is halfways decent to begin with.
    There are lots of Ford sixes out there if you want a six, they aren't spendy and are just as reliable. No adapters and Ford in a Ford will keep you some semblance of value for resale.
  16. samurai mike
    samurai mike
    do it just to piss people off. it's already working!
  17. BJR
    BJR
    You have quite an imagination if you think anyone here is pissed off.............. yet.
  18. There's only about 8 good engines to swap into a shubox and a slant 6 [or any 6 IMHO] isn't one. I believe the easiest is the old gen 1 small block chev. I loved my 355/350 turbo in my 49.
    BTW, a stock 49 ford 3 speed and original rear axle are NOT up to the task...even behind the original stock flathead 6 or 8 motor. I used a 70s Maverick 8 inch. rockyboxmotor.jpg rockboxnscotty.jpg [ATTAC
  19. squirrel
    if you have the engine, and you have the car, do some measuring. Where is the oil pan, relative to where the crossmember is? how long from the back of the engine block to the end of the water pump, where the fan bolts on? You should be able to tell how well it will fit from a few measurements, and some visualizing.
  20. The N00B
    The N00B
    thanks for all the replies. very informative. I really do appreciate all of your collective wisdom.
  21. jimmy six
    jimmy six
    You will need to get a new center for the grill it yours wasn't an original six.
  22. My '49 was originally a flathead 6. I turned the center bullet upside down. Made the un educated scratch their heads.
    ford495051 and belair like this.
  23. 73RR
    73RR
    In the long run, assuming that you actually get the car finished/driving, you will be happier with a 289-302 and if you have a manual trans you can keep it with a little effort.
    OR, you could put a Hemi in that thing......;)
  24. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    I'm a Mopar guy but IMO a slant is entirely wrong in this case.
  25. Just do it your already set for it anyway. Than when you get back on here asking 20 million questions about how to do this or that we can ignore you and just say. NOOB!
  26. belair
    belair
    ^^^^^^^ this is true. Be smart. We all want to different (just like everyone else), but there are GOOD reasons you don't see a slant 6 in 49-51 Fords. You can make the car yours in other ways (good way) besides an odd-ball engine choice. AND save a ton of time, $$$ and frustration.
