I did a search and couldn't find anything on this.I have a 216 in my 53 and I put new points,condenser,button and cap on the motor turns over put will not fire so I am guessing I need to set the points on it.Does anyone have any info on doing this and maybe setting the timing on it too?
Point should be set at .016 Turn over by hand till the rub block of points is on the center of one of the 6 flats on the dist. shaft, then set points to .016
Here is an excerpt from the engine tune-up section of the shop manual ... http://chevy.oldcarmanualproject.com/shop/1949_53/06engine/6_028.HTM Click 'next page' for setting the timing.
