216 chevy 3 & 4 cylinder not fireing
Discussion in 'The Hokey Ass Message Board' started by Bhm25, Aug 12, 2013.
  1. Bhm25
    Bhm25
    from Ny
    Picked up a 1950 chevy deluxe . It has the strock 216 in it which idles a bit rough shakes pretty bad . I tried pulling of the plug wires to the cylinders one by one and cylinders 3&4 appear to be not fireing. Didnt get to compression tester yet was just curious what can be some things to look for to diagnose . Checked the plugs wires and cap have ruled them out. Thanks for any advice
  2. NoSurf
    NoSurf
    so you are getting spark at #3 & #4?
    are those valves opening?
  3. Bhm25
    Bhm25
    from Ny
    Yea I have spark at 3&4 . There is no valve noise at all did not pop the valve cover yet
  4. NoSurf
    NoSurf
    if you put your thumb over the sparkplug hole and spin it over do you get any compression?
  5. Bhm25
    Bhm25
    from Ny
    Havent tried that yet . I do have a compression tester but its on loan for a few days lol
  6. Dan Timberlake
    Dan Timberlake
    could be as simple as 2 fouled plugs.
    or not
  7. NoSurf
    NoSurf
    if you get enough pressure to blow your thumb off the hole- you should have enough for it to fire.
    did you double check the firing order and wires and cap sequence?
    hopefully some others will chime in- i am heading home for the day from work. will check in there.
  8. SMOG_GUY
    SMOG_GUY
    from Dinuba
    At my job whenever I see cylinders next to each other not firing I first think blown headgasket.
    That's why you gotta do all the silly little disgnostic checks to rule that out. Is firing order correct???
  9. Bhm25
    Bhm25
    from Ny
    Fireing order is correct . Didn't get a chance to check the compression yet but thanks for all the tips .
  10. Bhm25
    Bhm25
    from Ny
    With out an official compression gauge test .they do seem to have the same compression as the fireing cylinders using the magical thumb over the spark plug hole
  11. NoSurf
    NoSurf
    Visible spark on#3 & #4 plugs?
    Sent from my SGH-T989 using H.A.M.B. mobile app
  12. Bhm25
    Bhm25
    from Ny
  13. junkyardjeff
    junkyardjeff
    Go and get you compression tester so there will be no guessing,are the two plugs fouled and have you removed the valve cover to see if any of the pushrods are still where they are supposed to be.
  14. NoSurf
    NoSurf
    Good fat blue spark? Maybe swap a plug out with a cylinder that is firing.
  15. tb33anda3rd
    tb33anda3rd
    1. Connecticut HAMB'ers
    also look for a vacuum leak at the center of the intake manifold.
  16. whtbaron
    whtbaron
    from manitoba
    Not sure I'm a big fan of that thumb test... seems to me any engine with enough compression to blow your thumb off, may also have enough vacuum to suck it in...
  17. Bhm25
    Bhm25
    from Ny
    Will post the results of compression test in a few days . I have not popped the valve cover off yet.
  18. fastcar1953
    fastcar1953
    my guess is bent pushrod or busted piston. have seen both do what you are talking about.
    pull the valve cover and see what it looks like. do compression test soon as possible. both will tell you real quick how bad it is. good luck.
  19. NoSurf
    NoSurf
    I guess I have really big thumbs.
  20. fastcar1953
    fastcar1953
  21. Bhm25
    Bhm25
    from Ny
    Will have the conpression results in a day or so did not forget lok
  22. Bhm25
    Bhm25
    from Ny
    Well a few things i have found one its not a 216 it is a 235 . The vaccume advance on the distributor does not work .
    Conpression is a even 145-150 pounds between all the cylinders .
  23. J'st Wandering
    J'st Wandering
    I don't think it works that way. On a four-cycle engine there is a compression stroke, not a vacuum stroke. ;) What would the vacuum be on an engine being cranked over with the starter? Maybe 5 pounds? I have never checked but pretty sure it isn't 145 psi.
    Neal
  24. midnight auto parts
    midnight auto parts
    from tn
    very good chance that the distributer is blessed with worn bushings and shaft.
  25. R Pope
    R Pope
    Triple check the wires, the two cylinders are close together, it's possible to cross them and not notice.
    The vacuum leak is a good suggestion, 3 and 4 are on the same intake port.
    Head gasket would be a possibility, too.
    It would have to be two pistons shot to cause both to not fire, too much of a coincidence for me.
    Possibly a stuck intake valve on one cylinder could act like a vacuum leak and cause the other cylinder on the same port to lean out enough to misfire.
  26. baggerman07
    baggerman07
    I have to say my 53 has a 216 and it was acting "about" the same way but my vaccum pot was shot also...buy a new one for $40 at National Chevy and forget about it..problem solved..
  27. Bhm25
    Bhm25
    from Ny
    I am going to test for vaccume leaks that seems like the most probable cause. The 2 cylinders defenetly are not firing like the others cylinder 3 has a very slight fire while 4 has completely no effect when i pull the wire . Also ordered the a new vaccume advance. Upon crunching casting numbers it is a 54-62 235 engine.
    Thanks for all the tips i will keep you posted i dont get to work on the car daily.
  28. If the vacuum advance doesn't work due to its diaphram leaking, follow the vacuum hose from it and see where it connects. Does it go to the intake manifold near the number 3 & 4 cylinders? Or does it connect to the carb where it would also be nearer to the two center cylinders?
  29. Bhm25
    Bhm25
    from Ny
    It connects to the carb near those cylinders. Hopefully it is that let you lnow thanks
  30. Easy enough to plug off the vacuum port and see if things improve. Or better yet, install a vacuum gauge there if it's a full manifold vacuum port and see if you can pull a decent, steady vacuum reading.
