21 Stud Flatty Overheated- Parts Source Help needed
Discussion in 'The Hokey Ass Message Board' started by 34FordConv, Aug 20, 2009.
  1. 34FordConv
    34FordConv
    Well, after three long years of work I finally got my ride on the road!
    I went for a test drive and it overheated, checked it out (thermostats, timing etc.) and could not find the problem. Did another run, same thing, but this time I found the culprit... Cracked head! Man did that ever bum me out!
    Now I need some help sourcing a set of heads and gaskets. Anyone know of a good source for these? 21 Stud (waterpumps in head) heads and gaskets.
    Any and All help greatly appreciated.
  2. pistinbroke
    pistinbroke
    Got you covered. P.M sent with a # to call, I'll have them waiting ofr you.
  3. Bruce Lancaster
    Bruce Lancaster
    There are several different heads and a hidden trap for these...look at numbers on head to ID. The trap is that some of these engines had flattop pistons and matching flat quench area in head, others used domed pistons and domed quench area...you gotta match your pistons to whatever head you get. Try for heads with same casting # as there are different compression ratios.
  4. 34FordConv
    34FordConv
    What a testiment to the H.A.M.B or moreover the HAMB Members.
    within 5 minutes of this post it appears my problem is on its way to being solved.
    A HUGE Thanks to Pistinbroke who has come through with parts and help that could never be matched.
    I only hope I can get the opportunity to help someone else in the same way.
    THANKS THANKS THANKS ...and that isn't enough
    34FordConv
  5. 34FordConv
    34FordConv
    Thanks for the info ... Will look closely to be sure of what I get
    GREAT HELP!
    34FordConv
  6. 34FordConv
    34FordConv
  7. pistinbroke
    pistinbroke
    That sure is a shame!!! I got the heads to my buddy and he will have them on the surfacer and done tomorrow. Glad to hear the gaskets worked out for you as well. Talk with you tomorrow.
